So next time somebody says "I'll bet it drinks fuel"It did less than 100 miles between 2012 and 2023 .
You can truthfully tell them, "nah, only needs filling once per decade"
"Last time the tank was filled was 2012!"
not yetMy front seats don't swivel unfortunately.
Van looks pure quality....and the foodI can’t see office layout this was very normal,and if I was buying anew morelo or concord flair I’d want the bar layout it suits us and our previous van had the same layout. The 2 front seats turn round making a nice social space.View attachment 943225
It seems to still be working as I had the panel disconnected for about 30 minutes and when I reconnected it the time and date were still correct so while the wee battery is corroded and I've ordered a new one it must still be working to some degreeJust take care with that control panel because mine shut down and would not come back to life. Sent to Appletree for repair who advised computer chip had lost its program or got corrupt so then had to have new control panel and fuse/distribution box as only N & B have their program for the chip! Probably needs power maintained, hence the little battery.
That is not the most flattering photo of Tam
Yes I checked that today Martin and will need re doing as its peeling at bits . I'm also going to re seal round all skylights etc once I've cleaned all the old stuff off . And a bead around that rear spoiler too .Looking good next time you are up there check the joint where the front cap meets the roof, it is Sikaflex or something similar but then it is taped over with something that looks like a foil backed bitumen tape and it is supposed to be changed/replaced every few years, I did ours with Eternabond RV tape which has something like a 25 year lifespan.
Proves it’s a strong vanThat is not the most flattering photo of Tam
I can't see swivels on them , there does appear to be levers on the sides with hoses going to them but dint seem to do anything. Bit I've not spent a long time investigating them yetDo you mean they should but they don't ? do they lift up ?
Well it's not your number one priority at the moment but yes the lever is attached to a cable that allows the seat to swivel, also another lever to lift it up to table level, sometimes the cables need replacing or adjusting and the lifting of the seat usually needs a bit of help as the gas struts get tired.I can't see swivels on them , there does appear to be levers on the sides with hoses going to them but dint seem to do anything. Bit I've not spent a long time investigating them yet
I have and during the low sun season, it's yield is incredible......Plenty of lovely roof space for some mega solar panels
Have you thought about putting them on tilting frames [ I think Martin jumar has at least one that tilts ]
I'm sure I've seen a similar desk layout in another A Class
Brains that layout is known as a bar layout. We had it o a 2002 Hymer and it was also on their top of the range, also on several other makes. It’s a great layout, far better in the current available on most ranges these days. Nowt to do with office at allI wonder what the story behind this van is ?
Why would anyone leave a very expensive 8 year old top of the range motorhome sitting in a barn for the next 12 years ?
12 years ago it could have been sold for a six figure sum as an 8 year old motorhome in very good condition.
Now after 12 years of storage fees and zero use I doubt Tam paid even a quarter of the value it once held.
I also wonder about the strange 'office' set up in the layout.
It looks like it was designed to run an office of some type with the accommodation as a secondary option.
Possibly some sort of race official ?
I wonder if things like the cooker and bed have ever been used ?
(For example our van when we got it had was nearly 2 years old, had 6,500 miles on the clock, the carpets and TV were worn out, but the the cooker and mattresses still were covered in plastic as they had never been used, but we know why)
Not such a strange layout, our Hymer B584 has a similar layout for the just a bit shorter and with just 2 of us find it is a good use of spacealso wonder about the strange 'office' set up in the layout.
Also removed the satellite dish and gave the roof a bit of a clean . Will have to give it a detailed wash under all the skylights etc but got a lot of it cleaned
View attachment 943192View attachment 943193View attachment 943194View attachment 943195View attachment 943196View attachment 943197
That would be perfect.Well it's not your number one priority at the moment but yes the lever is attached to a cable that allows the seat to swivel, also another lever to lift it up to table level, sometimes the cables need replacing or adjusting and the lifting of the seat usually needs a bit of help as the gas struts get tired.
I didn't see bar I saw office, how sad am IBrains that layout is known as a bar layout. We had it o a 2002 Hymer and it was also on their top of the range, also on several other makes. It’s a great layout, far better in the current available on most ranges these days. Nowt to do with office at all
Aye and the tightwad I bought it from ran it on that old diesel back and forth to garages for mot and cambelt and dragged all the shite up through the fuel systemSo next time somebody says "I'll bet it drinks fuel"
You will need to lie down in a darkened room when they have all gone
There’s a lever under the seat that when pressed send s ours up the turn round?are you sure yours don’t.
I could give you pair a big kissWell it's not your number one priority at the moment but yes the lever is attached to a cable that allows the seat to swivel, also another lever to lift it up to table level, sometimes the cables need replacing or adjusting and the lifting of the seat usually needs a bit of help as the gas struts get tired.
Yeah it's had a remis skylight originally I think same as the very front one and if like my hymer the wind has caught it and blew the top off ...they've had something taped over the hole till they fitted that heki .. and then never cleaned the tape off . Hopefully panel wipe will remove that residue .I saw those marks around the mini heki and wonder if it’s leaked and somebody had just taped something over it and that’s left residue.
I know I’ve had to reseal mine
I have all the manuals lol I'm just a typical bloke and haven't read them lolYou have done an excellent job of cleaning that roof, yes I know you will go back again, but the change is fantastic. This bus is getting the attention it needed 12 years ago.
I think you lot with the same model or near enough should meet up soon, so you can show Tam everything he doesn’t know.
I expect there is also a downloadable manual online. Not sure you didn’t find one
They come with an absolutely brilliant manual, ours went with the van when we sold it of course, it's just a pity Tam hasn't got one (well I guess he hasn't)You have done an excellent job of cleaning that roof, yes I know you will go back again, but the change is fantastic. This bus is getting the attention it needed 12 years ago.
I have all the manuals lol I'm just a typical bloke and haven't read them lolI expect there is also a downloadable manual online. Not sure you didn’t find one
The roof will come up lovely . I'm going to finish washing it tomorrow under all skylights etc ...then I'll reseal around all those before I polish and wax the roof. I suspect that big aircon unit doesn't work as I can't get any life out it but will have to buy a skylight to replace it with .You have done an excellent job of cleaning that roof, yes I know you will go back again, but the change is fantastic. This bus is getting the attention it needed 12 years ago.
I got all the manuals but there are so many of them lol I've not read themThey come with an absolutely brilliant manual, ours went with the van when we sold it of course, it's just a pity Tam hasn't got one (well I guess he hasn't)
Sorry Tam, but it has all the looks and fixings of an inverter, and that clear relay underneath is the auto switchover relay, which auto detects when you are on mains, or the inverter.That big box is definitely charger and not an inverter
In that case, they raise and swivel.I would have liked the front seats to swivel also but they are on a different level to the rear seating .
I'm no gambler, but I'll bet they do.My front seats don't swivel unfortunately.
As Martin's reply.Do you mean they should but they don't ? do they lift up ?
Definitely not a desk layout Stephen, ie, bar lounge layout, very much the same as our old Hymer E690.Plenty of lovely roof space for some mega solar panels
Again Tam, exactly as Martin suggests.Well it's not your number one priority at the moment but yes the lever is attached to a cable that allows the seat to swivel, also another lever to lift it up to table level, sometimes the cables need replacing or adjusting and the lifting of the seat usually needs a bit of help as the gas struts get tired.
That's why I love this forum, loads of help and informationI could give you pair a big kiss
I've just been out to check and yes the front seats lift up and swivel all from that one lever and are level with the rear ...that's bloody amazing . I had looked and thought they'd never be at the same level and that's why they didn't turn but they do .. I'm so chuffed I could break dance as it really makes it a nice lounge now. The dogs will be so pleased as the girls lie on the front seats but I always feel they're out the way then so now they're able to socialise.
Brilliant absolutely brilliant View attachment 943272View attachment 943273
