Pretty sure it’s more common with an absorption fridge.Not sure if that only works on a compressor fridge.........
You're the second person to tell me that tonight so I might just give that a try
Sometimes it works but most of the time it will start working but only lasts for a short while but worth a try.You're the second person to tell me that tonight so I might just give that a try
Some points I agree with but then some would say " I wouldn't spend money on a very old van " the genny isn't a priority at present but i would like to get it working as it will be useful .Everyone has their own opinions but I wouldn’t spend money on a very old genny, all about priorities I would maximise solar and lithium , and run a big compressor fridge, nothing worse then throwing away food, then making sure that everything water and heating and gas are in tip top condition , that makes for a comfortable living environment, on the chassis side of things, make sure that the engine is properly serviced, all fluids , injectors, all belts exhaust , nothing worse then a van which doesn’t run properly,
Then of course sort all brakes and bearings, which is easy peasy after the practice runs with moby,
Injectors can be tested, hopefully fuel pump will be ok
I'd rather source another 3 way fridge but I'd be inclined to fit a second hand one from a breakers etc than buy new . There's no way I'm paying out a couple of grand for a fridge .Is it a 7000 series fridge freezer with a seperate freezer above the fridge?
Have a word with Richard n Ann he converted a 3 way to compressor you can get a kit for around £500 a bit cheaper than 2 to 3 grand for a new fridge.
Aye but I'd have rather had the original 3 way fridge .Did you not have a domestic fridge in a previous van ?
Naw it's no I've measured itThink we will have too as it’s too big to get out the door…
Yeah I've had it on all the settings ...it gets warmer the more you turn it up . The freezer box is definitely colder than when turned off but it wouldn't chill anything never mind freeze itAnother thing with absorption fridges is don’t turn it up to maximum, that’s what I’ve been told before.
I tried to take a pic of that but couldn't see put my wee windscreen
This is the only time I'm on hookup lol.On hookup.....
Small domestic fridges are free...
Freecycle, Trashfornthing other freebie sites or a few quid locally or ebay
In a T3 Autohomes Kamper I had, the fridge stopped working. I took it out, turned it upside down overnight then turned it the right way up and replaced it the next day. It then worked perfectly for another 10+ years until I sold the vanSometimes it works but most of the time it will start working but only lasts for a short while but worth a try.
Looks like we'll be turning the fridge upside down .In a T3 Autohomes Kamper I had, the fridge stopped working. I took it out, turned it upside down overnight then turned it the right way up and replaced it the next day. It then worked perfectly for another 10+ years until I sold the van
Trevor
He’s plugged in now so no power problems, its a good van and I like it… the trouble with Tam is he sees the whole situation rather then breaking it down into what’s actually wrong with it.. eg: change bulbs buy a couple of taps cleaning scrubbing possible new burner for the fridge other little niggles that aren’t expensive to put right, just time and elbow grease.
The main thing now is the fridge, new like for like expensive so second hand or go compressor which is cheaper and in my opinion better so besides the solar and necessary bits to go with it and new batteries which Tam already knew he would have to do it’s not really a lot of money needed to put it all right. All the other things like mechanical can happen to anyone with any motorhome at any age and time so that has to be factored in, but I don’t think much is or anything wrong with it..
I’ve told him he can stay for as long as it takes us to get it all sorted, Tam is a fecking worrier and moans about what next to go wrong where as I am a let’s get off our ass and get it sorted one issue at a time but I have to admit that once we got one problem solved another was created from it..
I haven’t seen anything wrong yet on it that we can’t fix, and in the great scheme of things not a lot of it will cost a lot of money to put right and once it has it will be a fantastic van that will see him good for many years to come…
I meant just while you are fixing stuff ....This is the only time I'm on hookup lol.
I don't use sites hence I like the van to be self sufficient.
Yes Sue, I had very successful results with renewing the thermal paste behind the fins, as did tonka Steve and Chris51, who initially brought the subject up. https://www.motorhomefun.co.uk/forum/threads/3way-fridge-thermal-gel-replacement.225866/RE the fridge, turning upside down was a common fix as the old 3 way fridges didn't like not being level, talking at lest 20 years ago.
Am sure too I read a thread on fun about new paste being put into an old fridge as the old had hardened and was ineffective, get the feeling that JockandRita might have been on the thread.
Note. That WESTY66 mentions having put paste in his fridge and mentions Uncle Lenny too, might try picking their brains?
No point in bothering with replacing the thermal paste until it is basically working at the moment there is no cooling at all.Am sure too I read a thread on fun about new paste being put into an old fridge as the old had hardened and was ineffective, get the feeling that @JockandRita might have been on the thread.
Note. That @WESTY66 mentions having put paste in his fridge and mentions Uncle Lenny too, might try picking their brains?
Aye I know . Let's just hope he doesn't get pissed off with me meantime as I feel I've commandeered his entire life at the minute lol.Tam just remember how Toby was and you were in the same position saying it was very bad and look how that turn out .
I know it must be stressful but you’ll get through it with Just smiffy’s support.
