A very expensive option then.Yeah this is original and it's proper leather hide , my mum used to have a shop selling leather coats and bags so I was raised with it ...can spot the difference a mile off.
The downside is everything slides off it , throws , cushions even dogs lol . But easier to keep clean
Yeah it has quite a few of those. I think the original owner ticked a lot of boxes on the options .A very expensive option then.
It's just a thread for the renovations at the minute. I always do a new travel thread before setting off.Docs Holidays?
It's not the sort of van that people scrimp on when ordering new.Yeah it has quite a few of those. I think the original owner ticked a lot of boxes on the options .
My RM dometic type fridge was goosed in the van I bought. I took it to a dometic repairer in northeast to be repaired. It needed a 240v therm coupler, new burner and 12v harness. The guy said the key to repairing them properly is to remove the fridge and repair on bench as trying to repair through outside vents makes more problems due to access. Maybe you could try this and people who know how to fix fridges could talk you through it? It cost £370 to repair but that's NE prices, but I reckon the parts will not be that expensive?It's not that simple ... fuel filter etc needs replacement and I want to try running it off a can of petrol first incase the tank is full of shit. But other stuff has taken priority. Once I have the taps replaced and no water leaks etc I can take a look at that.
Might need a fridge first too as all my food is going off the fridge isn't getting cold on gas and only slightly on 12v or mains which I believe means its knackered. A shame as its in cracking condition otherwise.. looks better than any I've had on other vans .
But I don't know sod all about them , can it be fixed? I don't really want a compressor fridge I prefer 3 way fridge
Yeah that comes later when tight wads like me buy itIt's not the sort of van that people scrimp on when ordering new.
DPDWhat about, “Doc’s diagnosis, prognosis and rehabilitation?
Then that might well e the 'short' cables fault. Going from memory on my mates you can buy extension connectors that have longer cables but it is just as easy to lengthen them yourself with some wire & a soldering iron. Take them off one at a time & spray with contact cleaner first.You will know straight away if the cables are "tight" & too short.Used to be exactly the same on Peugeot & citroens of that ageIt
It's an injector light ..
As an ammonia engineer ,as said take it out , turn it upside down ,shake it about & leave for 24 hours. Then I would temporarily connect small gas bottle with rubber hose, 12v & test it before refitting Whislt it is upside down remove burner assembly again & clean along with the jet & don't forget to blow out the gas pipe that connects to the jet before reinstalling. Ammonia is a dirty substance & doesn't like being sat about unused.Might need a fridge first too as all my food is going off the fridge isn't getting cold on gas and only slightly on 12v or mains which I believe means its knackered. A shame as its in cracking condition otherwise.. looks better than any I've had on other vans
You're the second person to tell me that tonight so I might just give that a try
& as above that is the problem ,especially once you attempt to use them again they work for a while then block.Mine did the same .After doing all the above it was still working perfectly when I sold the van 5 years laterThis fridge might be in a 20 year old van but it's only been used for 8 of those years. Would be a shame if I couldn't get it to work.
yes definaitely looks like the circulation pump for pre heating engineWebasto thingy under bonnet , pretty sure this is the thing that heats the engine from the alde
Yes I was also thinking about that modification.
Scooter went in easy and is easily strapped in . Hasn't moved a mm since I put it in there and I've still room for a donkey
But you are going to Marocco you need room for a camel.Scooter went in easy and is easily strapped in . Hasn't moved a mm since I put it in there and I've still room for a donkey
Yes I think it's the cartridge that's knackered on these and water comes out the top below the lever.Northernraider. Tam, I have obviously missed the problem with the taps.
On our Flair, the vanity tap was leaking, (funflair. Remember the white piece of kitchen roll around the base Martin? ), so as both that and the kitchen tap were the same age, I stripped both down, cleaned everything up, re-assembled with a smear of plumbers silicone grease, and all was well for a while. A further leak later was down to the failure of the ceramic cartridge, so I bought 3 x from Screwfix/Tool Station at around a fiver each, replaced them both, and kept one spare.
Re filling the kettle, we have our water filter plumbed into the vanity sink tap, (A... easier to install and B... less water going through the filter), so we use a jug to fill the kettle.
The above might just save you having to shell out for expensive taps.
Cheers,
Jock.
Yes going to write a list today of stuff to check, stuff to fix , stuff to remove etcThe only thing that helps me (& my highly stressed, high achiever daughter) is making lists! Breaking a big task down into smaller ones, & WRITING IT DOWN gets it out of your brain, & stops thoughts going round in circles! I don’t know if you’ve done this yet, but as a lecturer who has seen many a nervous student through long essays & projects, I can tell you that it will help! The van looks great, & you will get it sorted!
Yes I’ve always made list when motorcycling and motorhoming your quite right.The only thing that helps me (& my highly stressed, high achiever daughter) is making lists! Breaking a big task down into smaller ones, & WRITING IT DOWN gets it out of your brain, & stops thoughts going round in circles! I don’t know if you’ve done this yet, but as a lecturer who has seen many a nervous student through long essays & projects, I can tell you that it will help! The van looks great, & you will get it sorted!
i dare youYes I was also thinking about that modification.
He’s plugged in now so no power problems, its a good van and I like it… the trouble with Tam is he sees the whole situation rather then breaking it down into what’s actually wrong with it.. eg: change bulbs buy a couple of taps cleaning scrubbing possible new burner for the fridge other little niggles that aren’t expensive to put right, just time and elbow grease.
The main thing now is the fridge, new like for like expensive so second hand or go compressor which is cheaper and in my opinion better so besides the solar and necessary bits to go with it and new batteries which Tam already knew he would have to do it’s not really a lot of money needed to put it all right. All the other things like mechanical can happen to anyone with any motorhome at any age and time so that has to be factored in, but I don’t think much is or anything wrong with it..
I’ve told him he can stay for as long as it takes us to get it all sorted, Tam is a fecking worrier and moans about what next to go wrong where as I am a let’s get off our ass and get it sorted one issue at a time but I have to admit that once we got one problem solved another was created from it..
I haven’t seen anything wrong yet on it that we can’t fix, and in the great scheme of things not a lot of it will cost a lot of money to put right and once it has it will be a fantastic van that will see him good for many years to come…
Need both, Gin with no ice is unacceptable.stop sodding about with taps and turn the fridge upside down its a priority
So is water lol. Can't flush loo or wash up etcstop sodding about with taps and turn the fridge upside down its a priority
Good shout jock , picked up a couple of cartridges, £4.79 each just fitting one now, no visible damage to the tap or old cartridge but I'm guessing there was a crack inside it . Hopefully this sorts one problem.Northernraider. Tam, I have obviously missed the problem with the taps.
Cheers,
Jock.
The closest I can find to both the Reich taps in our 2006 model is £55 each.If the cartridges are only a fiver I'd buy them , can get the Same tap on ebay for £20
That's a good idea,I do that with my portable gas fridge,and also done it with my table top electric fridge that is used outside in summer.Do it now whenever they have not been used in monthsMaybe will not cure your fridge problem but when ours stopped working efficiently (was during a hot spell) I had read somewhere about taking the fridge out, turning it upside down for 24 hours & refitting. Hubby just laughed at me but I did persuade him to try & it worked. Still a good working fridge 2 years later.
