Put something under the throttle pedal to restrict it's travel if you're gonna put a weight on it to increase the revs.
Dog ball works under the brake pedalPut something under the throttle pedal to restrict it's travel if you're gonna put a weight on it to increase the revs.
And Uncle Lenny won't be up for hours!!
Your battery does more than just provide electricity. It also shorts AC, spikes and transients to ground. Removing the battery from the circuit allows those spikes and transients to travel around, endangering every semiconductor circuit in your car. So not a good idea . If you try loading elec circuit up by putting on headlights, with engine running , alt should compensate if it does not then alt isn't charging .
Yes it's weird . I've completely removed a battery from a vehicle before while it's running and always stayed running.Bugger!
I’m not sure why it should have stopped the engine as the earth path should still have been available through the negative lead.
Hope it starts again for you.
Ian
Have you tried a jump lead from the battery to the engine earth?Yes it's weird . I've completely removed a battery from a vehicle before while it's running and always stayed running.
I'll vouch for thatSensible as it’s freezing on the south coast this morning!
Possibly the emergency fuel cut off is fed by battery circuit?On a diesel engine surely it's only the fuel pump that can stop it working?
I can't find the engine earth without it being on a ramp . Access is not easy.Have you tried a jump lead from the battery to the engine earth?
It's not modern it's 25 years old . I've removed batteries from vehicles running that have been newer than that. The merc vario being one exampleThat was true on old, 1950s diesels but 'modern' ones will stop if the battery is disconnected.
After a quick look they said the cable to the alternator has overheated. I think not, that cable is about an inch dia., at least 95 mm sq.
I know this is going to cost, but why not just buy a battery and put it on yourself, if you are wrong a spare battery isn't going to be the end of the world then you will know if it's worth spending on all this testing.It's not modern it's 25 years old . I've removed batteries from vehicles running that have been newer than that. The merc vario being one example
The alternator seems to be powering everything bar the starter battery .
It's basically like the starter battery is just an empty box.
That is what he is trying to do but it's hard work with these Ities.I know this is going to cost, but why not just buy a battery and put it on yourself, if you are wrong a spare battery isn't going to be the end of the world then you will know if it's worth spending on all this testing.
Sorry but I got the impression he was trying to borrow oneThat is what he is trying to do but it's hard work with these Ities.
I was resigned to that fact this morning , I went to euromaster to buy a battery but they didn't do them , they sent me to this guy . The street is very narrow , I'd need help to get the van out of here and I don't want to just leave as if it isn't the battery I may need their help. Personally I'd like to try another battery first but I've suggested that and he just says ne needs to check the cablesThat suggests that the battery is unable to accept a charge, ie it’s fubarred.
No, it’s worse than that, it seems that the starter battery is depressing the alternator voltage (as though its internal resistance is very low (although the ‘resting’ voltage doesn’t suggest that one of the cells has shorted)).
Given that you’ve exhausted all the diagnostic avenues it is looking like you’re at the stage of replacing the battery.
Ian
Well he was but he went there to buy one and they are trying to convince him it's not the battery.Sorry but I got the impression he was trying to borrow one![]()
The hab battery is inside the rear of the van . I don't want to damage it either. The hab side is all fine for once In my life and I really don't want to mess any of that up. The van is starting ok this morning as it has charge in it from the trickle charge last night. But its only just over 12v . I've temporarily disconnected the battery maintainer etc so it doesn't confuse this guy anymore by putting a charge in to the starter battery. I'll reconnect and reset the b2b and ablemail etc after he's done.Can't you connect your hand battery temporarily. It's lithium so don't think it will damage it to start the engine a couple of times? I don't have any experience of lithium so this may be a silly idea sorry if that is the case.
WhAts it showing at the leisure battery?I just can’t see how the alternator is not giving a reading at the battery terminals….
Whether the battery is Fiddlesticksed or not surly the alternator will be chucking volts at it…![]()
That's how I thought too because that's been the case with every vehicle I've ever worked on.I just can’t see how the alternator is not giving a reading at the battery terminals….
