You can obviously tell me to do one but on my wife’s and my first trip to Turkey, in a car, my son said to me “if something goes wrong just throw money at it”
I should have gone to SpecsaversIt’s Jade not Ela
Yes, for our 11kg dog, a quarter 1/4, of one 500 mg paracetamol advised. The person whom I am not allowed to mention said can give the dose every 4 hours if necessary.A friend of ours is a vet and said we could give our dog 1/2 paracetamol twice a day safely. It certainly helped. Our daughter has given that dose to her border terrier which looks a similar size to Jade. Hope it helps her
Thought it was the middle one... JadeIt's his big dog Ela who needs it not Milo.
I think you should have put my whole message in your response instead of taking phrases out of context.That’s what you (by default, have to) do when you don’t know what you’re doing. Tam, and his technical support network, do know how to diagnose the problem step by step.
The problem is taking longer to solve largely because Tam is travelling daily.
Ian
Sorry I thought it was Jade the middle size one. My standard poodle has a whole tablet when needed. I was also told to never give ibuprofen to dogs as it is not suitable. Just my opinion and I was told this by a vet. I do t like to think of Jade being in discomfort or pain.It's his big dog Ela who needs it not Milo.
Not everything thing of course but definitely material things,my go to phrase when thing go wrong “ You can always get it sorted with money” and it works anywhere generally.I used to work for farmers & the technical director & one of the owners, ,although as tight as a drum, had the attitude that money solved everything.
It is, it's Jade.Sorry I thought it was Jade the middle size one. My standard poodle has a whole tablet when needed. I was also told to never give ibuprofen to dogs as it is not suitable. Just my opinion and I was told this by a vet. I do t like to think of Jade being in discomfort or pain.
Yep but it helps if you have an endless supply of itNot everything thing of course but definitely material things,my go to phrase when thing go wrong “ You can always get it sorted with money” and it works anywhere generally.
Here's hopingGood luck tomorrow Tam, l reckon that battery has taken a hell of bashing and eventually they simply fall off a cliff at a moment’s notice.
You will be sorted tomorrow.
Well, maybe 1/4 for Jade. I found that it was best given separately in a bit of cheese or something so you know taken. If you give 1/2, no more tonight.Thanks to those who gave the information on the paracetamol for jade who is approximately 10/11 kg ...I'll crush half a tablet up in her dinner and see if it helps
I'm sorry it was me who got it wrong. You are rightSorry I thought it was Jade the middle size one. My standard poodle has a whole tablet when needed. I was also told to never give ibuprofen to dogs as it is not suitable. Just my opinion and I was told this by a vet. I do t like to think of Jade being in discomfort or pain.
The problem is he can't really do that until he is parked up somewhere for a couple of days., so he has a chance to get some charge into it if goes too low. That would have been the next step until it just died again.I feel for you buddy, if you found a space for tonight, disconnect the starter completely and take a voltage reading. If on it’s own steam by the morning reads low, the battery is done. If it reads close to what you measured tonight, it means you have a hidden discharge that takes the battery down. Fingers crossed you don’t need a new one.
Battery is flat at the moment relying on the Ablemail to charge it so he can start in the morning. If it doesn't I'll get him to connect a cable direct between the batteries for a couple of hours I know he has some 10 mm sq on board but it worked last night with the ablemail.I would temporarily disconnect the b2b and abelmail, then re connect one at the time maybe after 1-2hrs driving, and see what changes That way you can see what’s happening
If he stays put tonight, he can disconnect the starter batt for couple of hrs. If it’s a dud, the voltage it will fall of the cliff pronto. All he needs to figure out, it’s starting the van with the help of of the hab batt to get going to the shop. If he lives the abelmail on, it may help to start, but, it will hide a potential knackered starter.The problem is he can't really do that until he is parked up somewhere for a couple of days., so he has a chance to get some charge into it if goes too low. That would have been the next step until it just died again.
Hopping the battery has had it and that's why the volts aren't coming up with the alternator running.
Tam is fretting because he is wondering if the old alternator was OK. I'm fairly certain there was a problem with it as there was an output on the D+ at tickover but it went off when the reves increased so looked like there was a problem with the regulator.
Too late I gave her 1/2 a 500mg tablet in a but cheese so I know she's had it.Well, maybe 1/4 for Jade. I found that it was best given separately in a bit of cheese or something so you know taken. If you give 1/2, no more tonight.
I can't face messing around with it again tonight . I'm as drained as the battery . I'm just going to leave it till the morning and try to get a new battery.If he stays put tonight, he can disconnect the starter batt for couple of hrs. If it’s a dud, the voltage it will fall of the cliff pronto. All he needs to figure out, it’s starting the van with the help of of the hab batt to get going to the shop. If he lives the abelmail on, it may help to start, but, it will hide a potential knackered starter.
That’s what I would do. Even two wires from hab to starter, sit 20-30 mins, then you will be able to start with a dud up front.
It will be fine. It’s the total amount over the 24 hours that counts, rather like with humans. Hope it eases her a bit so that you can get your ferry and then see a vet in Greece. I think we will all breath a sigh of relief with you when you get there.Too late I gave her 1/2 a 500mg tablet in a but cheese so I know she's had it.
They should be able to do drop test to check for certain before you part with your hard earned.I can't face messing around with it again tonight . I'm as drained as the battery . I'm just going to leave it till the morning and try to get a new battery.
Did you read the whole post?
