- Nov 6, 2013
- 3,231
- 256,406
- Hymer B574DL
- Since 2011 (tugger for 20 before that)
We have a similar problem on our LHD 2017 Dynamic Line.
A few weeks ago the left side DRL light and front indicator started being intermittent and have now stopped working.
I spent a whole day swapping over headlamps and ballast units (ballast unit fixings were rusted), headlamp and ballast units appear OK.
So it looks like the problem is on the Fiat side. There aren't any fuses on the indicators on a Fiat they are controlled by an electronic module. I've checked the earth connections.
I have been thinking it could be a relay supplying power as both the DRL and Indicators are not working. I can't find any info of the relays and I've found it impossible to unplug relays in the under bonnet fuse box.
I will have a look at info SandraL mentions.
After reading most of this thread in conjunction with the HOG groups postings I have fixed (albeit temporarily) my non working front LED indicators and DRLs.
The very thin wires in the loom were badly oxidised and broken where the overly tight cable ties hold the loom in place.
IMO the ties crack the insulation, allowing air and damp in. The wires in my loom were broken at 2 out of the 3 cable tie points.
