Check for a loose connection first, could easily be that, especially as it mysteriously cured itself when disturbed.Thanks will look into it.
I would have used a silicone grease as Lenny says vaseline will rot them,I would wipe off the vaseline off with a damp meths rag, careful not to put it on anything else.Spent the last few hours lubricating (with Vaseline) all the roof light & blind runner’s so they now glide.
Also fixed the so annoying shower door catch which actually works perfectly now gone from thinking it’s a pathetic design to loving it
Carthago recommend it specifically for lubricating the drop down bed mechanism ... is that why you decided not to have one?Make sure you don't get it on the rubber seals Vaseline will destroy them. It is the last product I would get anywhere near a Motorhome it's petroleum based.
Hope there are no rubber bushes in it, wouldn't be the first time a manufacturer has given duff information.Carthago recommend it specifically for lubricating the drop down bed mechanism ... is that why you decided not to have one?
Nope, just squeaky metal bitsHope there are no rubber bushes in it, wouldn't be the first time a manufacturer has given duff information.
Kinky!Fixed the door bin, fixed the blinds...
Fitted a strip of RED led lights in the bedroom
Hi Tony, I’m sorry, what will the Vaseline rot?
Anything that's rubber, like if it got on a skylight rubber seal, its ok on metal, and seals that may look like rubber but are not, I have seen where vasaline is put on rubber water hoses to enable easy fitment and a year or so down the line they have softened, and swelledHi Tony, I’m sorry, what will the Vaseline rot?
Thanks Tony but I know not to put Vaseline on rubber. Plastic parts onlyAnything that's rubber, like if it got on a skylight rubber seal, its ok on metal, and seals that may look like rubber but are not, I have seen where vasaline is put on rubber water hoses to enable easy fitment and a year or so down the line they have softened, and swelled
Mine failed in France with less than 20k miles on it a few years ago. Only half the correct amount in it and no leaks! Common issue on Fiat boxes apparently.Done a job for a guy that works in a gearbox centre, he said---
"You better check the oil in your Ducato gearbox ,we get them coming in with water in the oil"-- It would cost 1k to fix it
I changed my gearbox oil this week:thumb:
I was just about to post a picture of exactly the same thing but the Sonax version........I use this on my cabrio roof seals and its great on all the MH seals, I did them twice a year in spring and before winter storage.I use this for all my door and window seals.
Gummi Pflege Rubber Protection For Door Seals And Windows | MicksGarage
Gummi Pflege Rubber Protection for Door Seals and Windowswww.googleadservices.com
John.
