Looks a first rate job! I wouldn't replace it
The key on our Fiamma Safe Lock, (You know, the one that swivels to cross the Hab. door opening) decided to go on strike half way through it's Lock/Unlock cycle.
Fortunately the fixture was in the unlocked position so it was merely a question of removing the item from the door jamb and removing the lock barrel.
A call to Johns Cross on Tuesday, resulted in a shiny new lock and two keys arriving today.
With MHF Discount, (thank you Johns Cross) Total cost £23.50
Yes, I took the 12volt pump fed to to the switch and then back to the pump, also I linked out one of the micro switch wires, I did this because that’s how somebody on F/b Hymer group had done theirs.That's a good idea and fix. Did you pick up the 12v for the switch from the pump lead? Would like to do similar as had to change tap switches 3 or 4 times on past Hymers.
The only thing I’ve noticed is the occasionally it’s gave a pulse on the pump. Also if you had a leak from the tap or pipe work the pump would run, good or bad I’m not sure.Yes, I took the 12volt pump fed to to the switch and then back to the pump, also I linked out one of the micro switch wires, I did this because that’s how somebody on F/b Hymer group had done theirs.
This is the switch I bought, but I managed to get one for £21
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=173075491246
No I put a wire that links out the micro switch ( the same as switch being on permanently, if that makes sense)Hi again Manic,
When you say you "linked out" one of the micro switch wires does that mean you added a switch? If so, is that just a switch on the live feed? Info would be appreciated.Thanks
I think you could just wire in place of micro switch, I did it the way I did because it was a proven method.Do you have to do that if you fit the whale pressure switch or is it an alternative?
...oh... and with reference to the above post...
... of course I was wearing my Corgi Qualified Engineer's badge all the time.
JJ![]()
Hi. Do you have a link for what you’ve insralledJust replaced the Fiat radio with a cheap Chinese Apple CarPlay compliant double din smart radio.
I got fed up with the micro switch wires breaking so I fitted a Shurflo pressure pump. No switches to break and much better water pressure.I’ve had a problem with the bathroom sink tap micro switch which has a broken wire. I failed to get the tap apart, a copy of a Reich I think.
We had to use the bypass switch I had fitted last time the wire broke for a month and half.
So I’ve now fitted a Whale pressure switch in the water fed pipe , so no more broken wire problems.
Seems ok at the moment but if it give trouble will probably go your way with pump.I got fed up with the micro switch wires breaking so I fitted a Shurflo pressure pump. No switches to break and much better water pressure.
Not keen on those Whale switches had bad experances with them in caravans.
