What have you fixed on your motorhome this week?
Apologies, this one is a bit epic...
I've been modifying my 5.4m Ducato PVC over the winter in preparation for travelling around Europe. There's not much internal space, so I wanted to free up as much as possible inside. I had a few ideas, but I didn't know the rabbit hole this would cause. I believe the project management term is 'scope creep'.
First thing was I asked 'Diamond' Dave Newall to fit an underslung LPG gas tank for me. As well as freeing up my 'inside but only accessible from outside' gas locker, it'd have the added benefit that I'd be able to re-fill in Europe. Dave had the van up on the ramp for a quick look for me before fitting to make sure it'd all fit. To fit the tank, I needed to clear all the existing underfloor gubbins that was passing through the area (the bay immediately behind the exhaust)... so it begins...
The main thing in Dave's way was the gas fed Propex air heater. The intake and exhaust pipes were poking though the floor right where the tank was going to be, so I had to move the heater. No problem I thought, there's plenty of space around the wheel arches at the back. So I ripped out the heater, its power and control wires and the gas connection and filled the holes.
There were also a few water pipes going through the new gas tank area that also I needed to move. So I thought while I was at it, I'd convert to an underslung grey water tank and re-do the plumbing. No more smelly water tank taking up space and sliding around in shower and no need to set up the waste in the rain when all you want it a cup of tea. I ordered a new tank from CAK tanks. It took me a weekend of skidding around on my back under the van to plumb it in. And about a week for my neck to recover.
When the van was up on the ramps, Dave pointed out that my rear suspension bump-stops were knackered... so I replaced them with some air bellows (see here).
The rear of my 5.4m PVC had a 'lounge' area that was largely useless. The seats were stupidly high off the floor, narrow and the overhead lockers meant you were always bumping your head. We quickly resorted to leaving it set up as the transverse bed all the time and just using the cab seats for lounging. Once the bed became semi-permanent, we found the storage underneath is really useful too. Problem was the slide-out bed base wasn't particularly sturdy, the supports through our 'garage' were annoying and nothing stopped everything sliding out underneath if I ever had to brake hard. And now I had added incentive because I had to find somewhere to fit the air heater. So for the last couple of weekends I've yanked out most of the woodwork for the old convertible bed-seat thing to turn it into a proper permanent bed with a garage underneath. I've built it with good quality birch faced plywood and painted it to a good finish using cabinet paint. I really should have tried to use lightweight ply in unseen places though as even though it's less complex than before, I've not saved any weight.
Instead of a collection of cushions from the seats turning into a bed, I bought a reasonable quality foam mattress from Ikea and hacked it to the right size for my bed platform. Much more comfortable.
The last bit of fun was fitting the Propex heater to a spot in the back of the van. It turns out that Ducatos have quite a few chassis rails around the wheels (funny that!), so there's not that much space to drill holes for heater exhaust and intakes. After several attempts (including drilling pilot holes that I had to re-fill) I eventually found a place where the heater would fit.... right where the leisure battery, EHU battery charger and solar controller currently are. After quite a lot of cursing, I removed all the electrics. No problem... until I realised the space remaining was about 20mm too short for the battery. The battery was several years old an of unknown condition, so I replaced it with one of a similar capacity, but shorter and taller. Then it was just a case of re-wiring everything to move 2 foot forwards in the van and then re-running the electrics and control for the heater.
So finally I get to go out in the camper next weekend. Yay!
Record post think it's the longest one my fix thread
Well done
Bill
(y)
I bought a set of Heosafe locks in white and had them sprayed to the van colours and fitted them today.
John.
Just ordered two rear wheal bearings ther is one starting to show a bit of play as we have a very height mileage holiday planed think its best to change them both
BILL
i have fixed nothing, and im bored, so may break something in order to fix it:eek:
Finally got around to fixing my broken drop link. Patience paid off and I was pleased the numerous applications of penetration fluid and wire brushing meant I didn't need to resort to an angle grinder or nut splitter
Applied Lamin-X protection film to those ridiculously expensive Hymer/Hella almond shaped headlights in order to hopefully avoid a broken one. As there was some left over I also did the fog lights. Not as easy to apply as I thought, though I have used the thicker one, I wouldn’t want to be using it on awkward shaped lights.
Reconnected a vacuum pipe that goes from the wastegate to a switchy-thing on the bulk head ( has it made a difference?? No.) Cleaned the knuckles on the awning legs, rewired the back lights. Now looking for new draw runners as one has split in half and the draw now looks like it's had one too many. Will be in Abergele next week for my birthday. Hopefully the decent weather holds.
Fixed the horn two oil leeks the side lights.
Will continue to do MOT preparation
Struggling to find anything I would class as serious or dangerous
Bill
Fridge panel control, gas water heater and hab heater. £149 for Dometic fridge control panel !
Had to replace the flush switch on the Thetford toilet which stuck on! Flush filled the pan with the contents of the cassette before we could switch the main pump switch off. Had to bail it out with a sponge and off course it happened at 11.30 at night. Took 4 days to find a replacement part in Elche. All working now so happy wife.
A split pin failed on/in the Gear Linkage and a pin popped out. We were recovered and taken to the site we were going to anyway (only about 300 metres or so away). Recovery came back the next day with the correct split pin and fixed the problem.
Green Flag :hugs:
Will get Jim to change title to what Green Flag Fixed today:rofl::rofl:
Good service that:clap2:
1 indicators solders sum wiring joint I had use Crimp's on
2 Sorted out the head lamp wiring fixed sum bad earth's
3 Fixed the speedo it works now
Finished of the led lights in the hab unit
Bill
Fixed the ashtray. Fed up of it falling open. Took some removing, talk about over engineered dash.
Half way through fitting a USB socket on the top of the dash. Removed lots of bit to find an ignition live feed, only to realise I didn’t bring the wiring dooooh
:think::roflmto::blush::crying:
The water system.
5 times I told the dealer, the water pump is failing. 5 times the dealer said, well look at it, perfect flow.
But my brain was in over-drive and slowly but surely a pattern immerged. Good flow of water, but get up for a pee in the night and pump runs forever.
We have an air leak. The inlet is pulling air.
So I took the pump off, cleaned and greased every O-ring joint, re-assembled and PERFECTION. Get up in the night, flush and a tiny brrrrp and pump switches off.
Not what we paid £££ for but what the hell, it works now and I understand it.
The water system.
You know what they say Brian, “if you want it done properly”. (y)
I had a drop from my gray waste tank, so I fixed it, it’s pissing out now :ROFLMAO::ROFLMAO:
Within reason, very true.
In this case the dealer was right, the pump was OK but he never got his head around the constant problem of taps farting a lot. It took me a while to work out it was a time issue before the farting, and then it was obvious, it had to be the pick up pipe draining back into the tank, so a small air leak.
If I was not up for some DIY then this post could have been another "go to the small claims court etc etc".
Top spares shop in elche mate decent prices had to replace water pump in my van cheaper than getting one at home. Hope the rest of trip is issue free
Dave
Hopefully fixed the leaks we encountered from the thunderstorms this weekend in Cornwall. Went to bed on Saturday night to find the bed damp in 2 places... the lightening was scary, but not that bad!
It's a panel van and water was dripping down between the rear doors. Just got home, so I took the high level stop light off. The rubber seal was looking OK, but it was caked in detritus. I cleaned it all up and put some silicon lubricant on it in the hope it'll seal a bit better. Behind the light there's a bit shelf of metal that forms the lintel of the door and it has bit of a dish in it that was filled with crud. I suspect it's been leaking there slightly for a while, but it's only when we get downpours that it's enough to overflow the dish. If it leaks again, it could also be my reversing camera, the actual door seals.
The other leak was from a flip-up side window. A small amount of water was running down the inside and then down the wall to the bed. It looks like the window has dropped slightly in its frame. I've shoved it back up and it appears stable. More silicon lube on the rubbers (ooooh-er!). Another to keep an eye on. I don't really want to take it to bits as I think I'll have to remove half the wall on the inside.
