Two on Tour
- Sep 16, 2016
- 11,376
- 62,935
- Elddis Autoquest 175
- Since 2010
The only guide to fitting the plates I can find is this one
It looks really difficult to take the Door innards apart in this way. Is this what you had to do?
Pretty much, although the guy in the youtube video is and animal and gives the impression of it being a struggle, but the video was a help to know the order in which to get at bits.
I did not want to end up with damaged plastic trim so bought a descent set of trim removal tools.
The only other tools you need are a philips screwdriver, a 10mm socket on a 1/4" drive ratchet, a 10mm spanner and a T40 torque drive bit.
I found it a little tight for space with my pork sausages for fingers so dainty little fingers would be a help and when removing the electric window switch cluster keep an eye out for the spring clip which will ping off. It took me a little over half an hour a side to fit them which included removing the Remis blinds and refitting. I also removed the door pocket to make removing and refitting the door card easier.
