Cal54
when I was at the scrap yard removing the engine I practically did lift it my shelf with the help of a sizor jack and sum lorry strapsUsing a hydraulic engine crane, Mr Wild Bill?
What a Woosie...
In the good old days your home mechanic would lift the unit up using a rope around his shoulders...
JJ![]()
I took the 6 cylinder engine out of my old mk 1 Zephyr many years ago using a plank of wood between the wings to stand on and a rope around the engine and round my shoulders.Using a hydraulic engine crane, Mr Wild Bill?
What a Woosie...
In the good old days, your run of the mill home mechanic would lift the unit up using a rope around his shoulders...
JJ![]()
I used to lift them with both arms tied behind my back, clever dick they called meI lifted the front of a steam roller with one arm tied behind my back when I was younger, couldn't lift a mamod steam engine now.
John.
Wet me pants laughing.I used to lift them with both arms tied behind my back, clever dick they called me![]()
... Oi ... you're supposed to be working on the engine, not your Mrs!Continue to work on the old bust should be finished by the weekend fingers crossed
bill
she is working well at the moment... Oi ... you're supposed to be working on the engine, not your Mrs!![]()
That is what they are legally meant to do. dim on lights coming on.View attachment 161322 View attachment 161323 Just found another setting on the control box where the DRL's stay on but the brightness is halved when headlights are switched on. This is exactly what my Merc. does when the headlights come on.
View attachment 164379 Modified dreve shafts reddy to go in new cv boots to put on tomorrow cv hints are good to go.
This part of the conversion complet
When get everything fitted and working and tested I will let you know GusThat is what they are legally meant to do. dim on lights coming on.
@Wildbill How much did the shafts have to be shortened Bill ?
I fitted new rear brake shows last week. Talk about doing a job twice . I should have changed them when I renewed the hand brake cable the week before !
Yesterday the water pump for H&Cold was playing up so had that out this morning. Over caravanaslorca & got new seal kit & reassembled run & tested all ok.![]()
Hope you get fixe soonCan't do any jobs at the moment, manage to fall over and fracture my left wrist, so plastered up to my elbow. 6 weeks they reckon, I shall go out of my mind not being able to do anything. Well pi##ed off!
That's a job I've got to do but I need the get the MH up on some ramps so I can crawl underneathReplaced my broken window stays
Also de-scaled the fresh tank and now the level indicator works once again.
Even managed to clean the grey tank and the level indicator now works for the first time in 5 years![]()
I'm assuming you mean the de-scale.That's a job I've got to do but I need the get the MH up on some ramps so I can crawl underneath
