rebuilt the cylinder head for my van will transport it Scotland tomorrow remove the old one and fit the reconditioned one looks like a week spring on the old one and the valve burnt out
bill
bill
Our taps also have filters at the outlet. Unscrewed them a couple of weeks ago and was amazed at the amount of muck in them.Fixed the spluttering taps which got really bad at Peterborough. Turned out the filter on the inlet side of the pump was almost totally covered up with a black grunge. No idea what it was but the taps now work at full flow.
They look great, I need to do this to my van - was it a kit and was it easy?Fitted DRL's
Hi, no it wasn't a kit but kits are available and simple enough to install.They look great, I need to do this to my van - was it a kit and was it easy?
Is that your headlight on at the same time as the DRL's, I thought the DRL's had to go off when headlights are on.Fitted DRL's:View attachment 161070
DRL's are indeed required to switch off when headlamps are switched on. DRL's are not covered in the current MOT testers manual so can not be part of an MOT test and therefore the incorrect operation of these will not cause an MOT failure.
Due the the brightness of DRL's so they can be seen in daylight they may cause unnecessary dazzle or discomfort to other road users at night which gives the police the authority to prosecute for the offence.
I retro fitted DRL's to our 2004 Ducato camper and fitted a little box of tricks that senses voltage to the headlamps when they are switched on and turns the DRL's off.
DRL's should also be switched on and off by sensing when the engine is running and this is normally done by sensing an output voltage from the alternator.
You're obviously entitled to your opinion but my own is that it increases visiblity/presence in all weather but particularly in bright weather.Why would you go to all the trouble of adding DRLs to a vehicle that doesn't need them? They don't serve any useful purpose, they're just something that the EU imposed on us without any reason or justification. It's bad enough that we have them fitted on newer motorhomes but at least they can be switched off.
View attachment 161436 View attachment 161435 Tidy up of brakes so they look better with the alloys ....
