makems
- Sep 23, 2011
- 3,483
- 28,456
- Sadly had to give up
Nah, Andy would only have to drill a 10mm hole for that!glory hole ?
Duraglit is a bit better or Tcut works good joy I find braso just a bit to harsh finish off with a good wax my Windows we're very bad and braug them back very well I have sum picks sumware of all the stages I used to do my windowsCould I use brasso on my mh windows do you think? They scratched from bushes and trees.
I've used Autoglm super resin polish with pretty good results.Could I use brasso on my mh windows do you think? They scratched from bushes and trees.
& just went to finish loading van to get away later & the inside temperature of the van is 36º.Well I now have a fridge that operates perfectly on 12v; 220v; & gas. Goes from ambient to -18 in freezer box & down to 0º in fridge on all of them.Just a pity that it is the old one that I removed 6 months ago
& not the new one that packed up 1 day after getting to the UK
Nothing ever works first go but getting there now.
Just covered Water Pump and Boiler with pieces of an old Duvet,
Frost forecast for tonight
Should I be doing that?
Push switch fittedNothing ever works first go but getting there now.
Fan was too thick for space behind microwave so had to do extensive remodelling
View attachment 128257 View attachment 128258 View attachment 128259
Smoke & mirrorsHow did you get the microwave tuned in to ITV Andy?![]()
100% successPush switch fitted
Job complete
View attachment 130549 View attachment 130550 View attachment 130551 View attachment 130552
That's a very weak point on the taps, I got fed-up with replacing the spout and changed the whole tap for a all metal one without a spout joint.Fixed leaky tap spout (splitting on seam).
Did a lights check before setting off for the New Year celebrations, only on checking the lights I found the front and rear near side (that's the left @movan, near the kerb hehe) top lights not working. Checked all the fuses etc and couldn't find the fault for the life of me. Ended up isolating all the top lights and went away as planned. What I did find was a large mouse nest under my dashboard. So today I've had to strip out as much of the dash as I could and cleaned out the nest. It was an old one thank goodness. Have to say that the Fiat wiring looked good and well protected. Unlike all the aftermarket gadgets that have been fitted. Very sloppy work, including those fitted by Autotrail.
I was expecting a lot of chewed wires, but was lucky as none had been damaged. It then took me hours to trace the fault and guess what, the utter absolute rubbish build quality that those morons who claim to be Autotrail builders, was at a fault again. A wire, half way inside the rear panel has snapped, with no way of accessing it to render a repair. On investigation I found absolutely no protection for any of the wiring running to the rear light, instead the wires were lose, running over sharp knife edges and just waiting to strip and fail. Shoddy, shoddy rubbish work by the famous Autotrail builders. Think they'd sell an awful lot more motorhomes if only they tightened up on their quality control. Even the wiring for the rear lights are a poor example of craftsmanship.
So tomorrow will see me re-wiring the rear end. I've also go some military reinforced cable to run the new wires through, so hopefully it'll see a more permanent repair for the future.
This would have cost £100's if someone had to put the vehicle into an auto electrician to repair and all because Autotrail couldn't be bothered to do a quality job in the first place.
View attachment 140915 View attachment 140916 View attachment 140917 View attachment 140919 View attachment 140921 View attachment 140922 View attachment 140923 View attachment 140924
