Unladen weight for speed limit purposes (14 Viewers)
Aug 16, 2024
71
219
Hertfordshire, UK
dipping a toe
Am I right in think the unladed weight for speed limit purposes is the MIRO, minus the following items?
  • Mass of unladen vehicle including tyre mobility system and onboard tool set.
  • Driver’s weight allowance of 75kg.
  • Fuel tank filled up to 90%.
  • 16kg allowance for gas cylinders.
  • 20% full fresh water tank and water system.
  • 100% full boiler.
  • Mains electric cable.
Reactions: 68c
May 7, 2016
7,933
13,486
West Sussex
Malibu Van 640 LE K
Since 2003
I think it's simpler than that? Your maximum permitted weight - 3,500 or higher?
Crazy system but the UK speed limit has nothing to do with the Revenue weight or the Maximum permissible mass. It is based on the unladen weight which is not shown on the V5C.
  • 100% full boiler.
You are probably not far off with those deductions, not sure about tyre kit and tools. My latest V5C has a Mass in service figure that is less than the required 3050kg so I assume I am ok for the higher speeds. You might get some figures from your Certificate of Conformity.
Emmit
8,349
18,795
Pilote Explorateur
Jan.2014
The unladen weight of a motorhome is, more or less, exactly that.
It can be started but there's bu&&er all fuel in it. There's no water, no gas bottles, no EHU cable, no driver, no management, no food, no essential, (and non essential for that matter) anything in it. Nowt, zilch, NADA.
If? the resultant weight is less than 3050Kgs then you can be with the Ferrari's and do 60mph on single carriageway roads in the UK.
Let me know how you go on emptying the van.
Upvote 2
Aug 22, 2007
2,799
36,947
essex
2017 sunlight t69s euro6
my v5 shows miro as 2810 with a gvw at 3500k
WESTY66
6,797
17,648
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
My V5 shows nothing!! Does that mean legally I can go with the cars??🤷‍♂️
How would they prove I was over 3050kg unladen weight??
Which incidentally I think I am🤭🤭but there would be nothing on the DVLA/VOSA database to say otherwise?
12,208
27,308
South Wales
Coach built Adria
Effectively they can’t tell as the unladen weight is before ANY additional equipment above bog standard vehicle.
MIRO is different from unladen weight.
WESTY66
6,797
17,648
South Yorkshire
But from a point of view from the law??🤷‍♂️🤷‍♂️ can they and/or will they do me??
WESTY66
6,797
17,648
South Yorkshire
If you have your cert of conformity it's on there
Yes it is, but does the dvla have access to that to issue a fine for doing 70 on a dual carriageway instead of 60?
Sorry to be pedantic on this but would like some idea!
12,071
16,836
I don't trouble myself with any of that based on the assumption that cameras don't care and the Police aren't interested. I travel wherever I judge it to be safe and sensible at satnav 65 / speedo 70 unless I'm in 20, 30, 40, or 50 in which case I travel at the posted limit. I've done this for 25 motorhoming years in three 3500kg and one 5400kg vehicles including when towing. So far no issues nor do I anticipate any in future.
4,657
10,390
South Lincolnshire
Rapido 7065+
Broken most bits now
Towing at 70mph 🤔
56,115
164,338
Depends on what the manufacturer states for MIRO it varies between manufacturers but generally you are right apart from the mains lead that is not included.
I have both the unladen weight & MIRO for my van, the difference is 185kg.
61
165
Just looking
You will prosecuted on plated weight. If you drive a solo lorry tractor unit plated at 44t over 7.5t weight limit, you are prosecuted at 44t even though you have no load or trailer on attached.
