- Jul 28, 2010
- 15,475
- 20,764
- Rapido 7090F 3 litre 160
- May 2010
He helped
Did you enjoy your spring compressor time?New struts plus bits to assemble from Coastal motorhomes with fun discount and Kilen spring from ebay for our Hymer.
Going to be a busy few days
Not done them yet, only got springs this afternoon but now I’m concerned with how the spring fits on the plate.Di
They are big boys, and need some compression when I did mine.
There is a step on the base which will be clear to see where spring seats.Not done them yet, only got springs this afternoon but now I’m concerned with how the spring fits on the plate.
Should the spring fit against this part, green arrow because it’s got a far gap.
I’ve got to get under van and compare original partsView attachment 665455
On the photo I show the step and I would expect the spring to register on this but it seems to have no register and the spring has nothing to locate it.There is a step on the base which will be clear to see where spring seats.
I assume the parts are for the MH or a car ... otherwise it makes me wonder what the co-codamol is for as it's often used for 'headaches'!A water pump, non return valve, Jubilee clip and some spade connectors, oh and some Co-codamol!
The spring sits on that ledge and the end of the spring sits against the step on that ledge.Not done them yet, only got springs this afternoon but now I’m concerned with how the spring fits on the plate.
Ok I will check spring end size.The spring sits on that ledge and the end of the spring sits against the step on that ledge.
Red circle to red circle. (But spring is smaller on one end (top) so may have marked wrong end)
Yes, after x5 years a part has finally failed on the Globecar side. I'm not the most DIY person on the planet so the Codeine was to calm Mr FixitI assume the parts are for the MH or a car ... otherwise it makes me wonder what the co-codamol is for as it's often used for 'headaches'!
I Bet that gets the grass flat to park the Motorhome on.New belts bought and fitted to my Bomford flail mower, last ones snapped (after 20 years)!
It certainly does but I’ve discovered it doesn’t like going over digger buckets or fallen trees buried in the long grass! Note to self;;; I must be more careful!I Bet that gets the grass flat to park the Motorhome on.
Just wondered why you haven't insulated the walls?Latham steel door.
£395 inc alteration to height and delivery
Today the roof membrane and trims should arrive. I've already fitted soffit and facias.
View attachment 660733View attachment 660734View attachment 660735View attachment 660736View attachment 660737View attachment 660738View attachment 660739
Found a full spec sheet on the charger from AliExpress and changed my mindA 250aH lithium battery.
Bought from the lithimshop as it is only 40 miles from me and all hand built to order
I also liked the fact it is supplied with and Anderson connector
I already have a programable MPPT solar controller, a Stirling B2B ( lithium selectable ) so all I need do is fit a different mains charger ( I am RARELY on hook up so just went for a 20amp jobby ( lithium specific ) from AliExpress at under £40
That’s an incredible amount of food for the money. You can freeze most of it too.Well hubby went to the local Co-op around noon and came back with this load of discounted grub ... total cost £14.83! One of the doughnuts is now sitting on a plate next to saying 'eat me' .... I'm resisting at the moment and letting the sarnie I've had settle for a while but it's taking a lot of will power!
View attachment 669249View attachment 669250
