Tam you wondered what the original charger /wiring was like my charger was replaced but otherwise original
This one Jon,Mine had 2 of the standard chargers and neither was putting much out so I junked them and bought new. Would I do the same again? no because I hardly use it because the solar almost always takes care of it. If I knew then what I know now I would just get a cheap battery charger and hook it up for now.
btw, the panel battery isnt easy to change, if original its a solder in job and a bit of a modification. Ive got a threadon it somewhere but can't find it. Grasmere9 I suggest you have a look too.
They should jack up and swivel.My front seats don't swivel unfortunately.
I wouldnt be too hasty with the A/c Tam. If its all dead its probably a fuse/connection whatever. Might be worth banking for another day.The roof will come up lovely . I'm going to finish washing it tomorrow under all skylights etc ...then I'll reseal around all those before I polish and wax the roof. I suspect that big aircon unit doesn't work as I can't get any life out it but will have to buy a skylight to replace it with .
It will reduce my height a fair bit too.
And then fit my solar on there across the back end .
Or just a clean up of connections and filters and a re chargeI wouldnt be too hasty with the A/c Tam. If its all dead its probably a fuse/connection whatever. Might be worth banking for another day.
Yes mine has a microwave built in under the hob .We put the microwave in the cupboard above the fridge and the TV at the front but we had a drop down bed so the TV was fixed under that.
Yes I have to investigate it further .. I have found a mains cable under the wardrobe that's been cut and disconnected and I'm wondering if that was for the aircon therfore indicating a problem with it. However I suspect having not been used in 12 years its most likely junk . But you never knowI wouldnt be too hasty with the A/c Tam. If its all dead its probably a fuse/connection whatever. Might be worth banking for another day.
I was at a microcar rally with really poor 4g Martin. Luckily plenty of other stuff to see.There has been about 10 pages since then Jon it's a fast moving thread this one, but yes you are correct except the manual for CBE says that message comes up after you have put in the SOS fuse, Tam has also identified that he needs the little battery changing on the back of the CBE panel.
He also has the proper manual from N+B but not read it yet
Yes the seals could have suffered but who knows?Yes I have to investigate it further .. I have found a mains cable under the wardrobe that's been cut and disconnected and I'm wondering if that was for the aircon therfore indicating a problem with it. However I suspect having not been used in 12 years its most likely junk . But you never know
Or has it had an inverter but been taken outYes I have to investigate it further .. I have found a mains cable under the wardrobe that's been cut and disconnected and I'm wondering if that was for the aircon therfore indicating a problem with it. However I suspect having not been used in 12 years its most likely junk . But you never know
I'm not sure . The wardrobe area and under it was a bit of a nightmare with cables as the previous owner had it full of satellite TV boxes and small inverters etc to power it then remote control boxes etc with all the wires running from there to front of van where TV was. I've been tracing and removing those cables over the last couple of days.Or has it had an inverter but been taken out
Not sure if that clear swutch under the charger is a change over fir when the genny is fired up to pass the 240v through the comsumer unit, same principal as the inverter switch like JockandRita had thought it wasOr has it had an inverter but been taken out
That's probably a good shoutNot sure if that clear swutch under the charger is a change over fir when the genny is fired up to pass the 240v through the comsumer unit, same principal as the inverter switch like JockandRita had thought it was
Happy to be corrected but I don't think there are seals on hab air con that need to be lubed as in car air con.Yes the seals could have suffered but who knows?
I was just going to post Tam you need Maceellan back he’ll sort that. Fancy a trip to Cornwall soon. Save him wondering what to do.Pity I'm not still with you Tam. I have solutions to hide ceiling damage that would look original. I'll talk to you about it if needed.
One important lesson for you Tam......read the manuals! They tell you stuff you don't know. Keep going pal
& get it changed as that oozing is coming from inside & one day it will just not workI have ordered a new battery for it anyway just in case.
John Russell's rotted the pcb around it so he needed to repair that as well.& get it changed as that oozing is coming from inside & one day it will just not work
One if mine was popping fuses when the compressor kicked in, and it turned out to be a capacitor, its been fine ever since. One thing is the compressor will only kick in above 18c ( I think). its in the book NorthernraiderHappy to be corrected but I don't think there are seals on hab air con that need to be lubed as in car air con.
Tam have you asked Gary if he would like to go to Marroc
