It's a good option but on ones I've done in the past with a bit of age on them I've found the bearings have been iffy too. Mind you that was ACR seriesI did suggest he fitted a new regulator.
If it's measuring 12.5v at the starter battery with headlights on you need to check under the same conditions at the alternator itself. Where is your earth clipped?OK so here we go
tonyidle Lenny HB
This morning as mentioned we are at 100ah 62% reading 12.3v
Start engine ....panel shows initial input at 16a and immediately starts to drop finally settling around 7-8amps
Reading at starter battery 13.9 at idle ....14v at 2000rpm
Reading at starter battery cable ebl 13.78v
Reading at habitation battery cable ebl 13.69v
Switch aircon and headlights on drops to 12.5v even at 2000rpm
The 17v thing was very weird and happened a day or so after I fitted the new control panel.
I had starter battery reading 7.8v but when van started I was getting 17+v from alternator when revving
Battery light on and a few other lights flashed up at one point
I hooked up to electric ...recharged batteries and it mysteriously has not happened since
All fine by the looks of itWhat's the alternator drive belt condition/tension like ?
I've got it up on axle stands now so i can access the alternator.If it's measuring 12.5v at the starter battery with headlights on you need to check under the same conditions at the alternator itself. Where is your earth clipped?
Where you have connected the black meter lead. When you test the alternator voltage clip the black meter lead to the alternator or engine metalwork.I'm not sure which earth you mean?
Cool ill check the voltage there tomorrowWhere you have connected the black meter lead. When you test the alternator voltage clip the black meter lead to the alternator or engine metalwork.
So at alternator im getting 14.28v at idleCool ill check the voltage there tomorrow
Either way I'm gonna be pissed as the alternator is a complete bugger to access and to remove.I still think you need a full test on the alternator as if you spend £300 on an EBL and find it's the same you will be well pissed.
I'm having probs understanding it myselfI'm still reading this thread but failed to understand it many posts ago. Keep going boys![]()
DittoI'm still reading this thread but failed to understand it many posts ago. Keep going boys![]()
I'm not confident there's going to be oneMe too, but looking forward to the Eureka moment!!![]()
basically he said if the voltage is fine then its OK lolOh dear.
But you are only masking the problem, always best to cure a problemThe simple solution is fit a B2B you know it will work , and in long run probably most cost effective JMHO
in an ideal cost no object world thats the answer I agree .But you are only masking the problem, always best to cure a problem
Look at my figures in post #7526 from my van with the standard Hymer set up.
No, I have 3 x 78a/h Gel's, if Gel's are low they will take a much higher charge rate than flooded. I would still expect to get 30 amps with flooded.in an ideal cost no object world thats the answer I agree .
is your battery bank same as Northernraider ?
Put your phone on video and stand the camera videoing the meter while your revving it...So at alternator im getting 14.28v at idle
Can't check alt revvs asl no one to rev it while I'm squashed under there.
So I'm not sure whats up but still only getting 5-7 amps showing on panel from engine charging
Why even consider the EBL? We've proven that what goes in comes out the other side which means the relay is doing its job.I still think you need a full test on the alternator as if you spend £300 on an EBL and find it's the same you will be well pissed.
But everyone ive spoke to that deal with these issues ie a&n caravans and apuljack...even the guy at gemcaravans today all say I don't need one the system fitted in my van is one of the best charging systems .The simple solution is fit a B2B you know it will work , and in long run probably most cost effective JMHO
btw at any point have you checked how many amps you can get out of the alt by switching everything on at once ?
My voltmeter needs two hands to hold it on to whatever I'm checking lolMaybe this is a rubbish idea but here goes.
You want better charge at leisure battery. To me this means raising voltage at leisure battery to get more amps to flow.
Connect voltmeter to leisure battery with engine running. Watching meter connect jump leads from starter batt to leisure batt.
If volts at leisure batt go up then more amps are flowing.
Question then is where is the poor joint, thin cable or other problem between starter batt and leisure batt.
If voltage doesnt go up as jump leads connected then wiring starter to leisure via ebl is ok and this was all a waste of time.........
From the tests we have already done it seems the wiring from starter to habitation is fine as getting similar volts all the way throughMaybe this is a rubbish idea but here goes.
