Northernraider
- Jul 30, 2017
- 34,342
- 250,593
- N&B Flair 8000ib
- AirOn and off since 95
Its only 2 months old thoughHmm.... I’m thinking dodgy cell in the battery....![]()
Nope no smells or anything out of the ordinary...and again the control panel ( which may or may not be accurate ) consistently shows all batteries at 100% and all sitting around 13.8v when I'm plugged in.I think the only way a charger can knacker a battery is by cooking it (over charging) have you heard it charging or bubbling ..?
You would get a smell in the van...
I know with two geezers and a girl living in the van you would get some similar smells...![]()
I'm not sure there is one on the fiat but others may know for sure ?Could the problem be the old earth strap fault that used to come up frequently?
I thought that the previous problems were on Fiats.I'm not sure there is one on the fiat but others may know for sure ?
Yep that was my first suspicion when I had battery problems back in march so I removed the earth strap and cleaned it all up ...to be fair it was already pretty clean but it seems ok.Could the problem be the old earth strap fault that used to come up frequently?
Haven't seen it mentioned on here for a while but a couple of years ago there seemed to be a spate of people having starter battery problems that stemmed from dodgy earth straps between battery and chassis.
Might be worth checking.
Richard.
Sounds like there is one if tams given his attentionI thought that the previous problems were on Fiats.
I've started the van a total of 7 times now since the problem this morning and its started fine each timevery weird
So I'm going to leave the hook up off it tonight and see if it still starts up tomorrow.
In other news despite my crap electrical skills I've fitted in a phone/tablet charging station by my bed so I can charge phone overnight
Done it via a switch so it doesn't cause any other drain while not in use ...View attachment 397820
I did the same Tam..... fed up with cables everywhere!
I used this for mine.Northernraider chrisinplymouth Where did you guys get the switch from as it isn't a Halfords item?
My one goes from battery to chassis and then on to the engine someplace...but where it goes to chassis is usually where the problem is ..Sounds like there is one if tams given his attention
Does it run from the gearbox to the chassis Northernraider ?
Heres a linkNorthernraider chrisinplymouth Where did you guys get the switch from as it isn't a Halfords item?
I got mine from CPC FarnellNorthernraider chrisinplymouth Where did you guys get the switch from as it isn't a Halfords item?
Weird,,BUSBY.Well van started this morning no probs again and a few times this afternoon
Pretty sure that 15 minutes on a charger and a 3 mile drive home didn't cure a flat battery .
You can propagate some plants![]()
Tam, are you thinking of the modified sink made by Motorhomebumpers in Essex? or by another supplier? I have just sent an enquiring email to Motorhomebumpers as I want to change mine also. It would be better for a manufacturer to tool up to make two at the same time.Been thinking about my bathroom sink and in hindsight I think I'm going to order the modified one so I have a little more room in there.
Well as if I needed anything else to fix my step has finally given up after those two great clumsy oafs in france broke it ...the rail has now completely snapped
Anyone know if you can buy parts for these as I don't really want to have to buy a complete step View attachment 399634View attachment 399635
