TM59
You can buy square and rectangular aluminium box section on ebay in various sizes. With your diy skills may be an option to replace broken part.
That's what I'd do. Replace both sides because the new sections will have square corners.You can buy square and rectangular aluminium box section on ebay in various sizes. With your diy skills may be an option to replace broken part.
I'm not sure what the company is called for the sink but I found his listings on ebayTam, are you thinking of the modified sink made by Motorhomebumpers in Essex? or by another supplier? I have just sent an enquiring email to Motorhomebumpers as I want to change mine also. It would be better for a manufacturer to tool up to make two at the same time.
Re your step. If you can’t get spares, could you get a rectangular/square tube to fit inside the arm to strengthen it. The break is around the hole for the hinge bolt so the tube could be drilled for this and with further holes either side for bolts (allowing for bolt head to not foul the frame on retracting). Just a thought.
David.
Make him a mini ladder.I can climb in van easy enough but milo can't lol
Absolutely ridicHillview Awnings list the part, better sit down - £176.
Looks like a DIY repair coming your way.
Thule Omnistor Awning Specialists: Hill View Awnings
Our specialist workshop supplies and installs world famous Thule Omnistor awning products, bike carriers and accessories throughout the UK and Europe.hillviewawnings.co.uk
Edit:
Found a cheap one for you only £145 here.
If you go that route get them to slide a solid ali bar into both sections before welding & then it has far more strength when you drill through for the pivot....might be an option to get it aluminium welded
That's a single unfortunately and I need a double![]()
Thule Electric Step SGL V15 12v 460 (Pt No. 309969)
This step was removed from my MH and replaced with new to effect a quick repair. The frame had cracked but has since been professionally weld repaired and refinished. I have serviced the mechanisms and the step is in fine working order, but not now...www.motorhomefun.co.uk
Any good to you Tam?
Ooh that would be good I might be able to salvage the part I needHi Tam
I have just replaced an old thule double step with a new single one coz the motor has gone and double isn't standard fit.
I'm right in the middle of something right now, but I'll post again later on, coz if it's any good to you, you can have it
The left hand scissor section would be great but im more than happy to take the whole thing if it's no use to you incase I break any other bits ...and im happy to give you something for it and of course the cost of postage. I've dropped you a pm message to make it easierThis is what I have... which bit do you need?
With 2 mirrors and great patience lolHow did you do the back bit, thats the scary bit for me, one slip with razor is one slip too many, I would end up having to repair it with all over grade one, which I dont want
I did the front sides, that was bad enough, took a fortnight to recover.
LES
Very bright but hard to see in daylightIs it brighter than it looks in that photo and a noticeable improvement ?
You've removed the Scottish flag
