Lenny HB
- Oct 18, 2007
- 59,719
- 187,830
- Carthago Compactline
Blimey in the time I was posting you got it in the shed.
Mine ran out in January so not qualified for extensionWe all do that even when it's the first one.
Has your one been extended so you can leave for a while?
1st rookie mistake .....checked all the lights etc yesterday ....missed the bloody number plate lights ....one is out ...![]()
Yeah they quoted £395 for replacing the belt and doing a full brake fluid change so roughly what I expected.Thanks for sharing your stories Tam.
Good meeting you in the flesh.
Did you get a price for cam belt?
When I go to the mot I pull the handbrake a good few times while driving along to bed the brakes in and get rid of any rust and glaze on the pads.... hand brakes are always a problem on motorhomes...Well unfortunately toby has failed on handbrake not being sufficient....the usual fiat problem so I'll have to whip the wheels off again and check the rear shoes etc ...might just need adjusted but will see.
Also got a quote for the cambelt and brake fluid change £395 all in extra £150 if I want water pump changed but it's not a belt driven pump on this so I dont need it done just now.
Well it's not considered dangerous but it is a fail so not drive able except taking back for retest which is fine as I wasnt planning taking it anywhere anyway.Is Toby still legally drivable?
Is a handbrake fail considered dangerous/major?
I'm not up to speed since the new regs.
See post I just put up .....I went to get another quote but they cant do it so it will have to be Alan's at cairneyhillSo Tam,have you decided as to who’s doing the cam belt?
Unless it isn't the battery but the cable to the solenoid loose ? That used to be the problem on mine for years . Nothing whatsoever, get out waggle lead & away we'd go. eventually cured it with another new terminal crimped on properly.I don't understand how that's possible
Yep it would have to be a serious drain.It must be quite a big drain to do that, I would think the starter motor would be a good place to start looking at first ?
I'll certainly check the wires going to the starter.Unless it isn't the battery but the cable to the solenoid loose ? That used to be the problem on mine for years . Nothing whatsoever, get out waggle lead & away we'd go. eventually cured it with another new terminal crimped on properly.
Just been talking to Tam I said the same it looks like something is killing the electrics I don't think it's the battery that's the problem.It must be quite a big drain to do that, I would think the starter motor would be a good place to start looking at first ?
It's a very weird problem and I do wish there was someone savvy with electrics nearby that could check stuff properly.Just been talking to Tam I said the same it looks like something is killing the electrics I don't think it's the battery that's the problem.
That why I mentioned the EBL’s on eBay, so you could swap and send you unit back.It's a very weird problem and I do wish there was someone savvy with electrics nearby that could check stuff properly.
Like we said on the phone getting an auto spark to check it out is not only expensive but theyve a habit of just replacing things that might not be the issue.
I've started the van 4 times now since driving it back the 3 miles from the garage and its started 1st turn of key each time.
I'm going to leave it off the 240v hookup just now and see how it is over the next day or two just randomly starting it up here and there ...
Control panel is showing all my batteries at 100% and all sitting at 13.5v at present with 0.9a going in from the solar...bright sunshine here now.
Problem is the faith I had in the van is slowly wearing thin .....
I'm sure this control panel is dodgy for sure and I've my suspicions on the ebl also but I'd have to phone a and n caravans or appuljack and ask advice on changing them
Complicated when you live in the van fulltime doing exchange postage etc
It's hard not to let the constant problems not get me down ....I know this is a good van overall I'd just like to have peace of mind with it as it's now getting to the point everytime I go to move it or do something with it theres issues ...despite me spending a lot of money trying to fix all its problems
Nah to be honest they just wanted me out the way as they had already said they couldn't do the cambelt work etc ...so just a case of them needing my van moved from blocking the garage.Did the garage not have any ideas about why it would do what it’s done.
Yeah that's what a and n caravans do to which I think will be the best wayThat why I mentioned the EBL’s on eBay, so you could swap and send you unit back.
Yep they said when they removed battery and put on their charger it showed 40%If it’s the starter why would the battery show 40%...?
