Properly telling you to suck egg's tam but have you a long handle screw driver to help pinpoint where it's coming from but I realize it'll be challenging through the letter box bonnet.
He is a big lad but I'm not sure it will be long enough.Have you got a long rod to put to your ear on certain parts of the engine to find the noise, I’m sure you know what I mean about the long rod….
30k it's been sitting around most of it's life. As you well know a prime candidate for alternator & water pump bearing failure. If you need to get someone to do it get it done in NI the Southern bit is very expensive.So much for low mileage engines eh , the hymer had 118000 on it , this has 30000 . Hymer had no rattles etc.
Can't get anywhere near that side of the engine from above. You really need to jack it up take wheel off and the plastic pulley covers etc.Properly telling you to suck egg's tam but have you a long handle screw driver to help pinpoint where it's coming from but I realize it'll be challenging through the letter box bonnet.
I can't tell lenny . I've taken a short video I'm just waiting on it uploading to YouTube. As I said it's still driving OK at the minute it's just noisy ...and definitely not right . Still getting this eml light coming on occasionally too if you try to push it in any gear .Not by any chance the infamous 5th gear problem. If it is a fairly easy fix if you can get the bits.
Don’t make it worse Tam, seek out a decent garage before it goes popI can't tell lenny . I've taken a short video I'm just waiting on it uploading to YouTube. As I said it's still driving OK at the minute it's just noisy ...and definitely not right . Still getting this eml light coming on occasionally too if you try to push it in any gear .
It's Saturday and because of the Queen stuff I'd be lucky to get it checked anywhere before Tuesday. And I don't know where to start looking for a garage. I'm peed off at the bloody thing . I'm going to head out of Belfast for now towards Carrick Fergus as there's a dump and fill point there at least . But will likely continue to whitehead as there's better options. If the weather is fine the next day or 2 I'll take the cover off to access the belts and pulleys and see if I can get a better look. Obviously it makes more noise when being revved but I can't rev and look at the same bloody time.Don’t make it worse Tam, seek out a decent garage before it goes pop
Yes it does seem to come from the pulley end but for some reason the noise changes when the clutch is pressed and released which causes the confusion. I'll need to take that plastic cover off to get a good idea so I'll need to move to where I can park up for a couple of days .Get a length of tube and use that like a stethoscope to isolate the area of noise ,from what I can hear on the clip sounds dry bearing at front end of engine HTSH
If you can locate where the noise comes from you still need the parts and by lack of tools and safe access methods maybe the labour too, do we have any members in the area you are in who could recommend their local garage and have a chat with their favourite mechanic?It's Saturday and because of the Queen stuff I'd be lucky to get it checked anywhere before Tuesday. And I don't know where to start looking for a garage. I'm peed off at the bloody thing . I'm going to head out of Belfast for now towards Carrick Fergus as there's a dump and fill point there at least . But will likely continue to whitehead as there's better options. If the weather is fine the next day or 2 I'll take the cover off to access the belts and pulleys and see if I can get a better look. Obviously it makes more noise when being revved but I can't rev and look at the same bloody time.
Aye there's been a rattle from the gearbox area since I got it..That could just be that the clutch release bearing is slightly noisy as well and so the two together changes the sound . Didnt you have a bit of drama with the clutch a little while back ?
I'm pretty sure now it's the pulley endIt’s hard from the video to pin point the noise it’s certainly sounds front end pulley but to confirm tape up the flywheel hole and see if the noise changes.
Aye those are my suspicions too .. it doesn't seem as bad when the b2b is off too . Which may point to alternator.It is hard to tell, but from your video I think I'd start with alternator and water pump bearings.
Sounds logical, especially if the sound changes when load on the alternator changes.Aye those are my suspicions too .. it doesn't seem as bad when the b2b is off too . Which may point to alternator.
I've just moved on to whitehead as a big parking spot here.
There's 5 other motorhomes too which are the first other vans I've seen since arriving in norn irn
I'll get a look at the van tomorrow
