Janine
- Aug 22, 2007
- 15,315
- 46,723
- 2006 A/S Nuevo
- since 1988
I have one in the garden made from a 12kg gas bottle.....
Is it remote control?
Thats why a double seat will be sourced. Also the storage box underneath comes in handyWill HRHJade be prepared to allow a fellow adventurer to share the passenger seat?
Jackies given up lol shes heading back to the peloponnese tomorrow and renting an airbnb for a week .
Im heading north east a little ...
Personally id never be leaving one burning overnight ...i dont have any heat on then and i wouldn't want to trust a burner that wasn't well known etc ....ive a few in mind i just havent picked one yet ....but likely the hobbit , the Cyclops or the grizzly.The lower the stove the better. Heat rises, the storage box under is nice but you will stow the wood in a locker so it does not move about. The flue, less bends less obstructions to draft, but also takes most heat out with it. Some damper will be needed 6-8 inches above the stove. Single skin from stove then a adapter to double wall to go through the sleeve. Single skin will melt the sleeve. Top exit is best for top heat for the kettle. Back exit does not give much heat to the kettle, most heat will go to the next obstruction bend. Best with a top exit, solid baffle plate inside and a baffle on the flue for nigh burn. Otherwise half the heat it will escape out. There is a company in Newbury that can make stoves to your designs, I got one from them few years ago for the house and is fantastic. If I would be in your position I would make my own, and make the fire travel zig zag before exits. A base box is just puts the heat out the flue.
Check out 3kg propane bottles and make one out, good steel.
I made one for the garage with a 13kg a 3kg and a pipe to force the fire up then come down to exit. It boils nice at the top.
Yes its certainly going to be strange ...ive got quite used to her being around and so have the dogs to be honest. It will take a bit of getting used to especially since i likely wont meet many other vans on my route home ...they are all as far south as possible.I think (without any innuendo) you will miss Jackie's company. You have been together quite a while now.
Mine will definitely be up at 18 inches to 24 inches from the floor ....ive 2 small dogs who love to fight and wrestle ...dont want them getting burned and i just prefer that look ...the top will also be around the same height as the worktop ...they are only small burners designed to be in smaller spaces.The lower the stove the better. Heat rises, the storage box under is nice but you will stow the wood in a locker so it does not move about. The flue, less bends less obstructions to draft, but also takes most heat out with it. Some damper will be needed 6-8 inches above the stove. Single skin from stove then a adapter to double wall to go through the sleeve. Single skin will melt the sleeve. Top exit is best for top heat for the kettle. Back exit does not give much heat to the kettle, most heat will go to the next obstruction bend. Best with a top exit, solid baffle plate inside and a baffle on the flue for nigh burn. Otherwise half the heat it will escape out. There is a company in Newbury that can make stoves to your designs, I got one from them few years ago for the house and is fantastic. If I would be in your position I would make my own, and make the fire travel zig zag before exits. A base box is just puts the heat out the flue.
Yes its not the warmest of vans and with no toilet or shower etc its not the easiest in this weather.I imagine those pop-tops are difficult to keep warm in those temperatures, so I do not blame her.
N-E? so you will be starting to drift away from your beloved - no not Jackie, stupid, I mean the coast.
Does that mean that without Jackie's Gbs will will not hear from you so much? If you splash out on buying some more I will pay, not just for me but also all those others who are enjoying your travels and posts. Let me know how to pay, on PM. Your travels will also help us when we finally get to Greece.
Safe and warm travels.
Geoff
No, a real Scotsman would be dressed in a kilt-bearing in mind that nothing is worn underneath-just shrivelled up and frozen.You big woof a proper Scotsman would be out there in his tee shirt & flip flops.![]()
I was only using jackies internet for a few days till mine renewed on the 4th which its already done ...although i do use more these days than normal so i have to be careful at times. But videos tend to use the most and with bad weather i wont be using the drone much anyway .
Life’s an adventure. You have a good time scale and only you can decide. Good luck and happy travels which ever way you go.![]()
Im just looking at weather etc and Bulgaria -7 in sofia and snowing etc ...lookinh at Italy its 2 degrees ...still not warm on any account ...but im not set up in this van for long periods of cold weather ...Go home the easiest & quickest route, although we make plans life is fluid so things change , COVID is making travel difficult & you’re mind is probably on the new adventure at home , forget about previous plans & do what you want to do![]()
you can travel within your own region in Italy but not supposed to travel between regions
For transiting italy you get 36 hours , but then its what country to transit to ... France you're allowed 24 hours to transit.Is that still the case if you are passing through?
Maybe if you had a channel tunnel booking for a few weeks time to show them it might help?
I haven't a clue, just guessing.
Could always start your van project off a bit earlier?Would it perhaps be wiser to start heading home by the simplest/most direct route may be with a chunnel booking as @oneman suggests?
Perhaps now is not the time for new explorations and traveling. World wide here is a lot oof fear about, it is unfortunate that it impacts on your adventure but perhaps now , with the pandemic and the B--x-t thing a low profile and discretion would be the best course to follow.
I panelled over the apertures from back to front with radius corners and hope to make a feature of the panel in matt black.Yeah i considered doing this method of putting aluminium in the original window rubbers ...like this guy has done View attachment 465460
But i think id prefer to just weld in new steel and brace bars for a smooth finish.
If i have any windows in the rear i think they would have to be double glazed units rather than the single glazed glass ones.
Be careful welding steel panels in the van you will get a lot of distortion.I panelled over the apertures from back to front with radius corners and hope to make a feature of the panel in matt black.
Lloyds coded welderBe careful welding steel panels in the van you will get a lot of distortion.
Thats a lot of driving in 3 days and im over 3.5tonneYou could stay in Greece until the middle of March, leaving a couple of weeks in the Schengen zone.
Bulgaria and Romania could be warmer then as its another 4 weeks ahead.
But if you go via Italy/ France you could still stay in Greece until the middle of March , just have your route/ ferry booked and use the motorway in Italy.
From Milan go through Switzerland ( yes 40eurosto pay, for a year, so you could return) then your route through Germany, Luxembourg, Belgium, France to the ferry.
This route can be done in three days so your test in Italy will be valid untill theU.K
Im starting to think that way with regards to most direct route. Its trying to do whats the safest and the cheapest without being involved in quarantines etc ...id still stay in greece till end of February at least but not sure i want to risk staying much longer than that incase of complications.Would it perhaps be wiser to start heading home by the simplest/most direct route may be with a chunnel booking as @oneman suggests?
Makes Switzerland even cheaper.Thats a lot of driving in 3 days and im over 3.5tonne
