This is my Starlink using a different wifi router ( peplink ). Bonded flat onto my roof.
I bought a 5g Samsung a22 for £140 and hotspot with my smarty sim for the rare times I find myself in a 5g areaIn case anyone is curious. New 5G routers are around £500 if you can't get included in a contract. Three/EE don't give them out unless you are definitely well within a service area.
So if you want one or want one without a contract this option is pretty good. £179 for an as new reconditioned unit. Still has 1 year warranty etc.
Get the cheaper of the two if you want an external antenna. The more expensive one has a faster spec but not antenna ports from what I can make out.
If you are near an area where three/smarty are providing service, or travel to one. This is worth a go. Works on 4G as well when 5G not available.
Peplink never heard of it.View attachment 737849
Maybe this https://www.peplink.com/mobility-and-specialized-solutions/starlink-solutions-page/Peplink never heard of it.
Any details version etc?
Is that not the wifi speed and not the actual download speed?View attachment 737849
Cheers HarveyCan anyone confirm if you can set up guest access on the standard Starlink router?
Return it , cancel and order again, there is always a cooling off period ?Nope. You need roam.
Starlink routers do not feature guest network functionality and lack ethernet ports.
200 devices for the Starlink router.How many concurrent users?
Edit: or devices?
We are not using EHU anymore so that’s the problem . Will be increasing lithium bank to 300ah soon but it’s still a lot of power consumption.If your on site with Electricity then power consumption is not worth looking at but wild camping or off electricity then yes it would.
Hundreds of satellites the system has and you can always do site research before you get there and see whats the best pitch clear north so no hardship.
Worth every penny at 260Mbps down.
I have my Maxview 5G system as a fall back and yes rent may be an option.We are not using EHU anymore so that’s the problem . Will be increasing lithium bank to 300ah soon but it’s still a lot of power consumption.
I’ve noticed you can rent the unit so I might consider doing that and seeing how we get on . I would keep existing netgear M1 router and external 4g booster for use when mobile .
My next door neighbour has it on his house.Now that the Camino (Tiekom) service has had its day and the continued roaming data challenges, as well as crappy data service in the UK, I’ve had enough of pratting around as I just want always on, full service broadband wherever I am.
So, the solution (I hope) is a Starlink Roam order was placed today. £460 for the hardware, £95 per month for the service. I know some may consider this expensive but I will no longer need a data tariff SIM in the UK for the Netgear, nor will I need the Tiekom data SIM for between 5 and 8 months per year and I can knock back the Popit SIMs to 10Gig each, so the difference is not that great really.
I’ve worked out a spot on the roof where I will be fitting a small frame to mount the dish whilst parked up. It will be a couple of mins job to climb ladder and four wing nuts to secure, connect the cable and job is done!
The cable will be permanently installed through the roof into my existing media cupboard and at present I will power from my main inverter, but I may switch to a small 250w Victron pure sine wave inverter just for this in the future, so I don’t have to leave the main inverter on all the time.
Starlink quote around one KWh of power consumption per day. The peak power consumption is 75w and average consumption seems to be in the 35w range (230v power ratings). Many North American RV users are suggesting that the power consumption is way better than Starlink suggest and better than they expected.
A new feature from Starlink should help with power use as you can set ‘night periods’ where the system shuts down during set hours to reduce power consumption. I’ve ordered and will fit another 200w solar panel to augment the existing solar. I actually needed a larger Amperage Victron MPPT and some bigger cable to the batteries as well, so not the cheapest exercise…
I’ve purchased a compact almost purpose designed electrical box to store the 75ft cable in on the roof when travelling. This will enable me to move the dish from the roof to the ground should I have obstacles obstructing the dish, but very easily without too much faff.
Will try and document a ‘how I did it’ incase it is of interest and or use to others and will of course let everyone know how good (I hope) this is…..
the expectation and promise from Starlink matches real world performance. Watch this space!
I've had my starlink up for a week now and it's working brilliantly. Hardly notice the difference from our 500mb fibre to be honest.Now that the Camino (Tiekom) service has had its day and the continued roaming data challenges, as well as crappy data service in the UK, I’ve had enough of pratting around as I just want always on, full service broadband wherever I am.
In France I paid 450 euros for the hardware and in France the monthly charge was dropped to 50 euros a month. Starlink site said 3 weeks delivery but it arrived in 2 days from Germany free postage.There is no pricing in Europe for this. If you search with a North American address, you will see the prices in USD for the flat mount high performance dish.
After consideration, it uses almost double the power of the standard dish. Hence why I’ve decided to go for the standard dish with minimal setup to start with.
My mid term plan is to flat mount the standard dish… phase two and very much after I’ve proven it works as I am hoping!
Keep us updated and will watch with interest. Currently rotating 4 X Popit 100GB (two mobiles and router) in Europe at £100 per month until we get back then then either have to cancel or hibernate at £1 per sim per month.Now that the Camino (Tiekom) service has had its day and the continued roaming data challenges, as well as crappy data service in the UK, I’ve had enough of pratting around as I just want always on, full service broadband wherever I am.
