It is interpretation if you said radios are not a ‘thing’ then in fairness it is reasonable to assume the individual is saying radios do not exist rather than radios have poor reception. Now in fairness Gromett has since explained his perspective.
If ever there was a case for the phrase...."does it matter"
Here it is..![]()
SpoilsportIf ever there was a case for the phrase...."does it matter"
Here it is..
Edit
Back to the thread..it looks to me Starlink.is gonna grow and grow. The consumption of data for everyday folks is growing rapid.
I will wait until it is available pRoam is available but only with the Standard dish.
Flat dish not Available in UK, it also costs about 2K more
Wow, that's quicker than fibre at home.
It has hit 220MbpsWow, that's quicker than fibre at home.
I think you will probably find that the terms are designed for the US market. Consumer law in this country prevents warranty void provisions that are excessive.Hi
Have you read the small print for starlink ref mounts, modifications and voiding warranty
It's a riveting read as any modification or use of non starlink items voids all warranty
If could print my own stuff or buy cheaper I would because who will know what happened to it or why
The device I mentioned in post #224 above has arrived and is really, really fast. I am really happy with 250mbps+![]()
It does run on 12v. I would however use a regulated supply rather than straight off the battery.Can it be modified to run directly on 12v
What speeds does it produce if not in a 5g area ?The device I mentioned in post #224 above has arrived and is really, really fast. I am really happy with 250mbps+![]()
Sorry to ask a stupid questionThe device I mentioned in post #224 above has arrived and is really, really fast. I am really happy with 250mbps+![]()
How long is a bit of string. Depends on your signal strength and how many other people are using the same tower.What speeds does it produce if not in a 5g area ?
If you can find a MiFi device that supports 5G... ???Sorry to ask a stupid questionBut what is the benefit of having a router over a MiFi devide….I can carry that around with me if I want ? I expect you’ll say speed
or is it because you attach it to a Startlink or something?
Ah right…thanks….I don’t have a computer or laptop. No I don’t use WiFi either…just a Sim in my MiFi device. I suppose that would have to change if I went down the Starlink route.If you can find a MiFi device that supports 5G... ???
For me the advantage of a full router is my computer and laptop connects to it via ethernet. I avoid Wifi where I can.
You do use WiFi.No I don’t use WiFi either
Ah a local WiFi network yes…I thought you meant Campsite WiFiYou do use WiFi.
A mifi is a router that routes your signal from the 3G/4G phone network to a local wifi network![]()
In my case I meant any wifi at all. I prefer to avoid wireless connections when a wired one is possible or practical.Ah a local WiFi network yes…I thought you meant Campsite WiFi
