- Mar 1, 2023
- 601
- 1,003
- Hymer
- 25 years plus 30 in a tent
Thanks…got it…every answer illicits another questionYes, one wire to the dish on the pole from the waterproof box, and mains to the router (or a small inverter for 12V). You can get an Ethernet converter if you want as well from Starlink.
You'll need a VPN outside the UK. In the UK it works to UK ground stations and you get a Starlink UK IP address, but here for example in The Netherlands I get a Dutch IP so would need a VPN.
I guess so, I preferred to have a more temporary system to set up in a few minutes when parked up. I wanted it attached to the van rather than on the ground stand that they supply as it made it less obvious (and made theft or fiddling less easy).
