- Aug 18, 2014
- 26,738
- 164,079
- Transit PVC
- 16 years since restarting
How about a claw? Not a clutch claw a groin claw remotely operated!Or as pampam suggested a paper spray/tear gas/fire extinguishant etc, operated via solenoid activated via mobile signal.
Untill you forgot to deactivate it before your European tour ..!A spring loaded barbed projectile central in the drivers seat![]()
No - you have just been badly treated by some toe rag who wanted what you had. I really hope you get it back undamaged.
It's the diagnostic port a multi pin socket in the fuse box that you plug a scanner into to read fault codes on the Ecu's and to update the ECU's.What’s an OBD?
So that it doesn't come up as stolen on ANPR etc. Or when some poor person buys it.Change the registration. And/or the chassis numbers
No you aren’t stupid, very sorry this has happened but hope you get it back in tact .Thanks, you're quite right. Stupid aren't I.
Sorry to hear this, I have put it on a number of motorhome groups, here's hoping you get it back soon.Fiat Ducato Autotrail Tribute pvc, silver, WU16HCA from Wells, Somerset. Just arrived back from France, was taken overnight, some one was watching. Silver with wavy stripes along side. Please lookout for it.
Thank you so much, the more it is posted the better. Here's a another pic that was taken last week it's a bit more representative. It's quite distinctive, in your face almost. Someone must have noticed it on its journey from here.Sorry to hear this, I have put it on a number of motorhome groups, here's hoping you get it back soon.
I think it's something you get from the QueenWhat’s an OBD?
Hi, sorry to hear about the theft of your beautiful motorhome, I can’t print on here what I think of the scum who did thisThank you so much, the more it is posted the better. Here's a another pic that was taken last week it's a bit more representative. It's quite distinctive, in your face almost. Someone must have noticed it on its journey from here.
That's what I was thinking, it was only on the drive max 12 hours. How did they know it was there at that time? It must have been targeted. Plus the equipment needed to break in. You bet they had new plates with them. The police said the automatic number plate readers would be pinging allover the place. Not with false plates. I watched a low loader pickup a car right outside here. It hoisted the car and drove off in a very few minutes. You could easily get a low loader up my drive in the dead of night. I was zonked out!sounds like the thieves may have used a magnetic stick-on tracker so they could track you without being seen following you home,they may have possibly had the opportunity to attach it from your stop at the layby or even on the tunnel terminal. we hope you get it back.
Have u ever thought of taking the engine out at nightDo they ask how many keys it came with when you bought it? No? Then how can they after,? Mine came with 1 remote. I now have 4 sets.
Really needs to be the locking type.
When in the UK I use every.
Obd lock is always on ,
Clutch claw,
Steering lock
Double locking external deadlocks on cab doors,
B pillar to cab doors internal 12mm stainless bolts. Rear door and side door have external dead locks. Rear doors have internal top and bottom shoot bolts .
Side door has upper internal
" anti,-peel" bars.
Tracker
Drivers door is the only door with any type of key operated lock but cannot be opened until internal door bolts are removed from inside the rear of van.
Van is always deadlocked access is only possible through side door using remote.
Alarm.
What’s an OBD?
