cash either way?
£1 a week any good to you Ian??
cash either way?
Ha ha, someone had to say it. Nice one.£1 a week any good to you Ian??
What do you want to do on a laptop that a chromebook can`t do
What do you want to do on a laptop that a chromebook can`t do ?
They do have limitations, but I changed to a chromebook and find it ok, but I find I still need my old laptop for some things, which is annoying.
Depends on what you want to do ?
What is wrong with a hosepipe full of water ? Battery never goes flat .
Ian, I bought a new laser level set a couple of weeks ago as I needed the little tripod for a second hand Pentax dumpy level that I had just bought, for doing my drains. Haven’t tried the laser level yet (the tripod was ideal) but have read up that they are not easy to use outside in bright daylight. Only paid £18 including delivery for it so not a lot if it doesn’t get used.
Is the job that you are starting on tomorrow all part of the big job that you were on when the lockdown started, or is a new client?
Stay safe, David.
Have a good and safe day fella! ?hi David,,, this job is a big garden wall mate, nothing to do with the builder that I’ve done bits for, customer rang me last year, well before Xmas and it’s now that it’s come to fruition!! ( what a great word,, fruition) lol. Xx
Have a good day and look after your back.Well I’m off !! Wooopieee something to get up for, and something to do!
I reckon my fingers will be bleeding by ten, they’ve gone as soft as a baby’s bum!!
I shall update this evening,, so I shall see you then! Have a great day! Xxxx
Good evening,, well I had a lovely day,,
Got to work about 7.15, half hour drive, put kettle on, made a brew, set out the walls,, and found out that the laser level I bought from amazon for £44 is a piece of shiiiiiite,,
Can’t see the laser from 3 feet away let alone 15 mtrs as advertised! Unless your in a pitch black corridor I suppose,, load of bo,,,,,,, s. Anyway,,,,
I decided to split the wall into 3 lengths, and put expansion in between,, so I started on the lower length, around 1800 cm high, 9 in with piers, and I put a basketweave pattern in a frame, because it breaks up the size it’s going to be,,same in the other two but obviously bigger patterns as the walls get higher towards the house, some 2.7 mts at the far end!
anyway, the weather was lovely and I plodded on till about 4, cleaned up mixer etc,,, it was great to be back at work, customer is well pleased, so I’m happy!!
View attachment 384927View attachment 384928View attachment 384929
Looks great Ian but I got to ask what was wrong with the old wall.
Looks good after so long off. I bet you got back ache.
Phil
you need a green lazer for outdoors still not good in sunlight
It is green Mitzi,, just not strong enough!
why green ??
Quality brickwork Ian. You have confirmed what I had read about the laser level. Glad I got the dumpy level, no problem in using in daylight.
David.
