- Oct 25, 2016
- 6,257
- 38,300
- Bailey Autograph 79-
- Lots but slow learner.
Fitted a dashcam.
Mounted a USB power supply for it on the switch panel to the right of the steering wheel
Fitted a dashcam.
Is that response because of my forum name?The most subtle ‘fish’ related response yet.
Ian
Awww cmon .Is that response because of my forum name?
If so that is pathetic!
I think we need to thumbs down or an ‘unlike’ button.
It is just trimmed next to the strip, link eairler in the thread post #143, bought the adhesive with the carpet.morning Lenny
can you please tell me how you got the carpet to go under the door trim or has it just been trimmed very close as it looks great
and has it been stuck on with a spray adhesive, if so which one, a link to that and the carpet would be great btw.
Al
I agree and I didn’t start it!It's banter like this that upsets him. If you want to read about the mods save the silly chit chat for other threads.
Hi Lenny, I’d like to do the same, can you tell me which other fittings you used to match the Carthago pipe work? Cheers.It was a Peglar, fitted one to the last van so knew it worked OK.
Hi i fitted the Alde one that comes complete with John guest fittingsHi Lenny, I’d like to do the same, can you tell me which other fittings you used to match the Carthago pipe work? Cheers.
Not suitable for a Carthago as they & most German vans use 10mm flexible hose.Hi i fitted the Alde one that comes complete with John guest fittings
I used these, ½" BSP x 10mm.Hi Lenny, I’d like to do the same, can you tell me which other fittings you used to match the Carthago pipe work? Cheers.
Change the filter insert annually cost about £6.All good practical stuff your doing there Lenny - How long do you get from that size inline filter?
We don't have a TMV on the van, and I have been surprised a couple of times - On previous boats they were plumbed in immediately after the hot tank so affected all the taps but were set quite high - just not as high as the water in the tank which could be scalding - any reason you've gone for just the shower?
You will need to trim the carpet down to fit in the channel. I pressed the edge down with a hot wallpaper stripper knife then trimmed it with wire cutters.On a lighter note uncle Lenny HB my aluminium channel has come for the step carpet and I’ll be doing that tomorrow, cheers for the tip
That sounds frustrating in a new high van. I get that it might take a while for the hot to come through, but the tap shouldn't be capable of splashing everywhere if on full power.Change the filter insert annually cost about £6.
If I fitted the TMV after the tank it would be too cold for washing up, pipes were easy to access for the shower, I set it for a quite hot shower and usually just mix a bit of cold with it.
We only have one tap in the washroom one of those pull out shower ones, we have found if you want a basin full of hot water you need to run the tap at full blast until the hot comes through and it splashes everywhere, not a problem when having a shower. So we find it quicker to fill the basin with a bowl full of hot water from the kitchen as it wastes less water.
If I can get access I will fit another tap direct to the hot supply.
It's a very compact washroom and uses the same tap for washbasin and shower was OK until I fitted the TMV also changed the shower head for one that delivers less pressure but wider spray area.That sounds frustrating in a new high van. I get that it might take a while for the hot to come through, but the tap shouldn't be capable of splashing everywhere if on full power.
I’d just like to thank you Lenny, that’s another job and more expense you’ve led me into! I immediately said to the wife, “ I’m going to do that”It is just trimmed next to the strip, link eairler in the thread post #143, bought the adhesive with the carpet.
Does JG not do 10mm or supply adopters Lenny? I know they do a lot of different sizesNot suitable for a Carthago as they & most German vans use 10mm flexible hose.
He should organise workshop weekends, each weekend with their own specific mod, 100 pounds per entry lolYou are so good at all this Lenny, it's almost annoying!
I’ll remind you when you put mine inAnyone fitting a TMV don't forget to knock the non-return valves out, or you won't be able to drain any pipes after it.
