Lenny HB
- Oct 18, 2007
- 59,284
- 185,743
- Carthago Compactline
Yep need to get the air suspension fitted first.Will you be uprating it?
YepGoing full?
Oy thing that made any differ was the full air suspension.Just out of interest, Lenny, when you sell or part ex your old moho, do all your mods make any difference to the value or the price you get ?
My old B544 (could have been one of your old ones) had loads of extras and fittings but getting a p/ex price none of the dealers seemed interested. In fact of 4 dealers from around the UK, they all gave the same value.
But London is in the North.Some of the best/cheapest pubs in London are Sam's.
Get a move on thenRight you lot Jim has tidyed up the thread so keep yourselfs under control I've got loads of stuff to put up.
May need a couple of joiners and a bit of pipe, easy job probably hard for you.I need to revisit this thread as I want to move forward my waste pipe like you have done, anything I should watch out for or need to buy?
Goody. I unwatched this thread as I thought you had abandoned it.Right you lot Jim has tidyed up the thread so keep yourselfs under control I've got loads of stuff to put up.
If it hasn’t got any wires, I’m goldenMay need a couple of joiners and a bit of pipe, easy job probably hard for you.![]()
Some people are tyring hard already.Looking forward to the continuation of your thread, hopefully it won’t get spoiled again.
I've got 4*100 panels on my 143Hi Lenny, thanks for reopening the thread.
On post #47 there's an image of your solar panels, did you take the feed from the roof, through the fridge vent, rather than drilling a hole in the roof, maybe you have some images showing the detail?
I'm looking to fit 3 x 130w panels on our 143 when it finally arrives, I've got the T tourer so won't be able to get a panel upfront.
My current thoughts are:
390w solar & victron MPPT
Multiplus 2 3000w. (We have a Dometic AC unit fitted)
Shunt, to read
Batteries van already has a 90ah Super B lithium, I need to add more capacity, but my thoughts are that I'll not be able combine a Fogstar 300ah with the 90ah Super B? Realistically I'd like at least 300ah.
Drawing courtesy of DomK
Cheers,
Neil
My friend DomK has drawn out as attached and I'm pretty sure I can't get 4 panels on the roof, there's no room at the front, due to roof vent.I've got 4*100 panels on my 143
Mine are NDS aero ones.Sizes based on Craig Solar 130 w 115cm x 58cm
No 2 seperate glands onto a 100/50 controllerNice, have you used 2 slimline up front and standard at the back?
Does the feed go through the fridge vent?
Cheers,
Neil
