stewartwebr
- Jun 6, 2010
- 1,541
- 5,528
- Morelo Empire Liner
- 36 years and 16 motorhomes
Did you tick the box for the microwave, air conditioning, dishwasher and washing machine to be fed from the inverter? Believe it or not it is an extra but based on lithium selection as the base package cannot support the load.I'm not sure what happened last night but the heating hasn't been working or at least to its full potential.
It's set for 22 degrees as it's 0 degrees outside, we have hovered at 16 degrees, but I think that's just because we have that hanging dryer on as Phil did some washing last night.
I will sort it out when we get to Benidorm later.
Another annoying factor is that the washing machine is not on the inverter system, so at present, we can only use it if we have hook up.
Not good enough, someone definitely dropped the ball on that one.
Another hack you may consider is a T Line from the Alde hot water to the washing machine to allow you to use gas to heat the washing machine water, we have it done for both the washing machine and dish washer and it saves a lot of power by not using battery power to heat the water.
