New update video has been posted
Will he ever learn ?
Maybe plug and fry!!Supposedly all PLUG & PLAY
pretty much none, the whole selling point was plug and play.Can anyone explain what the advantage of this system is over upgrading to lithium batteries from normal leisure batteries ???
Apparently he paid for it . Iāve never been a fan of GJ as you know but I think ( and hope ) in this case heās checked his facts and has a legitimate complaint over this system . If heās bodged something then this video will be deletedI havent watched the whole videos, I seen the install a few weeks back when he unpacked the kit, but did he get this one the free then for "promoting" it,
if so , at least hes give an honest opinion that its shite after all, a lot would have kept quiet, to scrounge more gear,
ECOflow wont be happy, oh dear !
The fact he went public makes me actually respect him a little bit , but this has happened before with GJ and lithium technology so I remain open minded .GJ gets a lot of bad press, but in this occasion it really isn't down to him. The system he installed was supposed to be plug and play and IF it worked would have been a great option for self builds.
Looking back on it, the bit I don't understand is why did he post the initial video, before allowing the company the opportunity to 'make good' or resolve the problem. All he seems to have done is destroy a companies reputation and limit his chances of getting his money back.
I'm not suggesting he shouldn't have 'gone public', just that he should have perhaps given them the opportunity to investigate and resolve the issue or take ownership of it.
Life is full of things that go wrong, it's how they get put right that really matters.
its still here LOLThe fact he went public makes me actually respect him a little bit , but this has happened before with GJ and lithium technology so I remain open minded .
Ps
I still need to collect that dam fridge off you
I'm going to give the benefit of the doubt and assume he posted to do the right thing.Looking back on it, the bit I don't understand is why did he post the initial video, before allowing the company the opportunity to 'make good' or resolve the problem. All he seems to have done is destroy a companies reputation and limit his chances of getting his money back.
After a rubbish day at work this was absolutely hilarious to read .especially as he is now complaining that he hasnt heard back from them since posting the video on line. i suspect the next thing he hears from them is via a lawyer .....
Bring back the vanlife YouTube funny channels lol . Apparently travel trolls got them all shut down lolI think Renogy have offered something and now the clicks count!
At the end of the day, it's a box containing an inverter and a battery - it's basically an UPS.I'm going to give the benefit of the doubt and assume he posted to do the right thing.
IMO, that system is just overpriced junk. To give an example, I can't see how a plug in connector (instead of bolted) can deliver enough power via an inverter and be safe?
It didn't catch fire, but it was pretty close. I know he's done daft things (including his new solution in the video, again IMO), but it doesn't make him a bad person. He's a YouTuber, not an expert. I think he has just cut off a fair chunk of money for others benefit. Which I can't complain about.
As for EcoFlow, I've had talks with them myself about supplying their products. It didn't take much of an email exchange to put them on ignore.
I just hope he didnāt. At the moment GJ is calling EcoFlow out for being rubbish. I guess we await their results and responseand someone bodged the repair.
No, the solder is not holding the joint, the crimp is, the solder is only to fill the miniature cavities that exist under normal crimping (just a touch of solder nothing more) then crimped again while under heat, this enables 99.9% none resistance, the joint then shrinks when cooling to enable stronger hold, idea of this kind of joint is to reduce resistance nothing more, the compression and the shrink holds the joint in place, these are crimps at either end, never, ever in the middle.You should never solder crimped joints it really is asking for trouble.
No, I havenāt seen any explanation, but in fairness I think itās supposed to be a quick and easy 12v/230v system that anyone with little or no experience fit in their van. But that said Ecoflow should ensure the kit is safe enough to fit. I thought that it would be designed to eliminate amateur joints and connections so make it saferCan anyone explain what the advantage of this system is over upgrading to lithium batteries from normal leisure batteries ???
Absolutely nothing wrong with jointing cables - if it's done correctly. We regularly used to joint up to 630mm2 CSA singles - anything bigger was too much of a fight. I've seen the type of jointing shown in the video in a few Asian countries - we used to sing the "twist and wrap", although not sure they ever realised we were taking the P. Even seem them do it on overhead LV lines
My best guess is that the cable was damaged someplace, and someone bodged the repair.
However, If someone had taken into account fault discrimination when sizing the protective device to the cable size and load, then the fuse / MCB would have blown / tripped.
Perhaps it was all a giant conspiracy by one of his competitors? If GJās van was gutted by an electrical fire no one would be surprised and it would be put down to operator error. The nearly perfect crime.
No I am not being serious, for once there might be something to learn from his videos.
No, even in a house the wiring you are not supposed to do yourself is the kitchen and bathroom.With electrics installation in a van, do you not have to have them signed off as per a house by an approved sparky ?
