Current U.K. law on up plating has been changed WITHOUT consultation (88 Viewers)
Jonno1103
1,429
1,614
Harrogate
F Line F70
Current U.K. law on up plating has been changed WITHOUT consultation.
When up plating from 3500kg RFL will continue to be £365 pa. IT IS NOT being reduced to the PHG rate of £165.
Secondly, the DVLA are no longer changing the V5c to illustrate your new weight. The MTPLM will remain at 3500kg. This means that if your motorhome is detected on road installed Weight In Motion Sensors - WIMS, you WILL be classed as overweight. Currently there is no plan to prosecute although you will receive a letter advising you of weight limits etc.
This legislation is causing a great deal of harm to companies such as SvTech who are currently in constant communication with HMG and it is fully expected to be escalated and discussed on the floor in the House of Commons.
However, one of the reasons why in the short term this is in force is due to the EU's 4th directive and once in place will mean that RFL will illustrate the new entry weight limit. Vans & Moho's will need to be over 4250kg in order to qualify for the reduced RFL.
The Fourth Directive...
The EU will ratify this and it will be in force from January 2025. This means that drivers with post 1997 licences can drive upto 4250kg whether EV or ICE powered. Licences will become digital and some medicals will be self assessment.
Current information from Downing Street strongly suggests that the U.K.'s original stance was to also adopt this following an announcement during the March 2025 budget. The U.K. has historically adopted the first 3 directives and will also adopt No4.
There is now however a strong suggestion that this will be announced during the late October budget and will be in place for newly registered motohomes from March 1st.
This is of course still to be confirmed.
Aug 3, 2024
99
163
Greater Manchester, UK
Don't have one yet
I'm a newbie
Rather than start another thread, hopefully someone can help here - very interested in a 3500kg van that is known to have a poor payload - so want to increase that.
If I applied to have it done today, does anyone have any intuition as to roughly when it would be done?
I've tried ringing SV Tech but no luck, and there website is undergoing some work I think.
Thanks in advance 👍
MichaelT
4,087
8,685
Colchester
Carthago I 143 LE
Since 2016
Thanks in advance 👍
Depends what needs to be done, once SV have told you if it's something you can do yourself then the only wait is for parts and then DVLA, if you need to book in for Air assist or something then likely to be 2 to 3 month wait then DVLA.
140
524
Hampshire, UK
Weinsberg
Please keep us posted as that is almost what I did except I used VWE to provide the weight change certification otherwise the same weight change as you. The DVLA have changed everything except the revenue weight and Taxation Class.
May I ask what vehicle category yours is in, N1 or M1? That may be the difference.
M1
416
323
Low profile
I'm a newbie
As has been reported here, one person has been up plated correctly.
There has not been a change to the law or construction & use rules.
This is simply a person or persons at DVLA trying to change the interpretation of the rules.
If a vehicle weighs more than 3500kg it is classed as a heavy goods vehicle.
As to the EU directive allowing a motorhome upto 4250kg to be driven on a category B licence, being adopted here, who knows. It would not under the previous government, but may be under the current government.
Don't hold your breath as they have much more pressing issues to sort out, than a few thousand motorhomes weight limits - as certain parties have ensured we are an island off the coast of Europe with our own set of rules.
1,660
3,600
Coventry
IH N680CFL
Since2014
Thanks in advance 👍
Depends really.
Mine recently took 2 weeks for a paperwork exercise.
The previous one was only slightly longer as it required rear air assist. SV Tech supplied this for me to fit. Simple enough job. They still do all the paperwork and did not need any proof that you have done the work. Although maybe as I bought the kit from them helped. I got the new V5 before the work was done.
