- Dec 2, 2019
- 4,090
- 9,134
- Rapido 7065+
- Broken most bits now
£3k for an exhaust, I mean £3k for an exhaust wtf they'll be asking for £1.2k for a bit if brake pipe next
I appear to be in good company
You, me and the king
No longer as I've jumped out of the frying pan and into the Fiat, I mean fire.
This is why one must keep on top of these jobs as they get flagged up. Should have reacted to the warnings.
Sorry,
I am just sharing, it’s not going to change our lives just caught me a bit below the belt
Thursday I had a biopsy which has confirmed I have Cancer
Friday cat curled up and died on the settee
But MIL now home and improving quickly
Prostate, so hopefully easily treated and fully recoverable
Hi David, apologies if you've answered this elsewhere in this thread but where do you live and is there still work to be done on the motorhome? I use an excellent mobile sprinter engineer, who may be able to help. Regards Jonathan
And the pleasure the Hymer has given you over the years and will again when it's sorted, it's only money David and I think we are both lucky that we can afford it, onwards and upwards and good luck with the treatment look after yourself and Bev.Thanks, work is now scheduled to be done by Mertrux M1 J28 10 miles from us next week, with a failed MOT I have already moved it twice since then and now just going to leave them to resolve
We have had words over the exhaust which did disappoint me, other than that their observations seem fair and what price do you put on safety
I rang Weds this week to check progress to find there are problems getting some of the parts, in particular the ‘expensive’ bit of the exhaust
I felt I had been told it all came as one piece and all needed changing , I am both technically useless and naive
So I asked to come down and have a look before they did any more
Saw MH from inspection pit, there is a lot of corrosion , top still looks lovely and had just been valeted , but it’s a 2005 sprinter chassis only registered in 2009 but nearly 20 years old
The exhaust is not hanging off I now have a much better understanding of how this fits the brackets hang in rubber mountings Which are all good. The exhaust itself has u shaped loops welded to the pipe. It is the welds that have failed, but the exhaust is still very secure sitting in the brackets , you only know it’s loose if you lift it
Mercedes say there is no way it could have passed an MOT, I ask why, it’s not blowing or in danger of falling off as I had thought from their description
Then I get to the expensive bit, DPF ? Very secure why change that I ask
Merc service chap says its best to change everything
But this is working, stainless steel so no rust or rot and secure, with an obvious bolted connection behind it to connect the next section
Return to office
I know I said get on with it but I am now not happy and do not want this DPF bit changing
But we have special ordered it
Well special cancel it, not needed , I do agree to change the two end sections which do look ready
A technician appears , ‘did you miss the hairline crack in the weld on the DPF bracket’
Yes, but I still don’t want it changing, I will get it welded, if it breaks and the DPF is still working
So now hoping for around £4K which oddly now sounds quite cheap
Hopefully 2 more years of trouble free motorhoming , not sure we can afford the diesel though
Generally I’d agree and my van is always looked after by an independent specialist, but my car failed it’s MOT big time last year and the nearby supposed ‘experts’ (locally highly praised, but no longer by me!) had done such a poor job of ‘repairing’ it even after I’d taken it back twice that the main dealer had to redo the whole lot, and the ‘repair’ had made it difficult for them to properly fix it, even with all the oem parts.Highlights the madness of just giving a main dealer to do whatever they think needs doing. An independent will charge half the price and only do what absolutely has to be done. Would have saved more than enough to get somebody to sort and treat the corrosion underneath
Must admit that when we first get our motorhomes my first job was to lay underneath and give everything metal (not exhaust or engine) a couple of layers of propper outside gloss house paint, brake steel pipes included. Colour a mixture of whatever I had left in part cans at home in the garage. Another bonus is being able to identify it should it get stolen and recovered. Must crawl underneath and check it over some time.
So now I’m very wary of recommendations unless they’re from people I know and trust.
Not sure why the garage recommends changing both track rod ends if only one is bad.
I have heard of several exhaust,s been done this way worth at least talking to themFor 3grand, I would have thought you could get a Stainless Steel exhaust system from a S/S specialist.
Mine has no Cat or DPF but only cost £600 about 5yrs ago.
I maybe interested later in the year if they are around the gloucester area.Hi David, apologies if you've answered this elsewhere in this thread but where do you live and is there still work to be done on the motorhome? I use an excellent mobile sprinter engineer, who may be able to help. Regards Jonathan
If the one is being changed purely on age related wear and tear as opposed to premature failure I would be doing both as wellBack to my gullibility maybe seemed sensible to change both, brake discs are off and it’s virtually only the part price
I took it to be a bit like tyres, change both on same axle even if one still has some life left
Normal procedure.Not sure why the garage recommends changing both track rod ends if only one is bad.
I thought ball joints generally failed when the rubber boot split, let grease out and sucked water in. So one joint could fail but the other might be perfect. That said, I guess if the rubber has perished enough to split on one side the other joint rubber might be equally perished.Normal procedure.
If one has failed the other won't be far behind.
Same applies to brake discs etc.
