- Apr 6, 2019
- 4,760
- 9,539
- RV
- FourWinds Windsport 6.8L V10
Re-tensioned both my large Seitz Blinds and replaced one central catch - available from O'Learys.
All wired up. Saniclad stuck to walls of shower /toilet. Taps assembled & fitted to sink which has been installed & piped up & drain cut thriough the floor..just need to connect cables via switches to fuse board.
Bit late now but did it not fit better turned 90 as wouldn't be up against the skylights? Unless its a perspective thing.Another upgrade rather than a fix for the Cheyenne. Added a 150W solar panel to go with the existing 100W which I installed 2 years ago. The 100W installation has been very useful in keeping the batteries topped up but, with a compressor fridge, it showed its limitations once or twice last year. As you can see, it is a very, very snug fit
The EC325 solar charging is now redundant as it has now been replaced with a Votronic MPP 250 Duo with an LCD Solar Computer display. Should squeeze every last electron out of the sunshine now.
Yes, I know, the rest of the roof needs cleaning as well.....![]()
Your lucky apulljack have had mine nearly 4 weeks and it not back at garage yet.fitted our reconditioned e box so we now have power again
Like the fans, did something similar on ours
Fridge seemed to work better after
Only down side is there is a slight background humm when on as noise travels through the woodwork. Ideally want to be rubber mounted. How noisy are yours?
Interesting that you don't appear to have a roof-top upper vent for your fridge but instead have a side mounted one.They are very quiet - they are rubber mounted at the four securing point. The centre fan has a speed controller - pointless after testing it because it only seems to go fast or faster! The two outside fans are just on/off.
They are mounted to draw air out, through the top vent BUT could be moved if needed.
Same as with most others I have seen, including my Hymer, 2 wall mounted vents for the fridge, one top and one bottom. The top one is where I have put my cooling fans too. Mind you I only use a cover on the bottom one in winter. I have a roof vent as well but it is for the tech tower oven, not the fridge.Interesting that you don't appear to have a roof-top upper vent for your fridge but instead have a side mounted one.
Ah, that might be the reason then, we don't have a tech-tower with an oven, our oven is fitted below the sink.Same as with most others I have seen, including my Hymer, 2 wall mounted vents for the fridge, one top and one bottom. The top one is where I have put my cooling fans too. Mind you I only use a cover on the bottom one in winter. I have a roof vent as well but it is for the tech tower oven, not the fridge.
Nope, both on the side. Above the freezer is the oven which has a rooftop’ chimney type vent.Interesting that you don't appear to have a roof-top upper vent for your fridge but instead have a side mounted one.
How do you think they perform?..........The top one is where I have put my cooling fans too.......
Very well so far. Fridge noticeably cooler in hot weather (from memory!!).How do you think they perform?
Good stuff. We’ve not tried our van in hot weather yet but it was my perception that the fridge wasn’t particularly good.Very well so far. Fridge noticeably cooler in hot weather (from memory!!).
9 days for oursYour lucky apulljack have had mine nearly 4 weeks and it not back at garage yet.
I phoned them again yesterday and they have still not sorted the problem with the charging side of the e box. They where going to try something else yesterday afternoon and let me know today still heard nothing. Rest of box worked ok it was just the charging side.9 days for ours
