it is mild stell to brass cant seem to get it to braze john the brass is to thin can you get the part I cant seem to getIf it goes wrong Bill, I'll send you a new one!
one any where very happy to buy one if you can put me in right direction
bill
you adjust hand brake cabal probably a stupid QFinished installing wheel cylinders & rear flexible pipe. adjusted shoes, bled whole system,adjusted & greased wheel bearings, Refitted wheels then had to find a torque wrench that'll go to 130lbs/ft Adjusted hand brake cable but something isn't right somewhere as both adjusters are near end of travel yet shoes are adjustedspot on. It is like the cables are a shade too long ? Still ,all works ok.
Took out for a test & all working ok. Stroke of luck.
My thumb!! Managed to split the top of it in half with the hedge trimmer this afternoon. All stitched up. Now waiting for the pain to start!!
he's just a wimp and he was needing a pee the havens opened up two min after that pick any we we managed to get it covered up before it washed away it should be starting to cure in a few hrsBill, it looks like you need to strike it up pretty sharp to warm the wee man up he looks frozen.
Martin
We fixed our pizza oven well almost just got a few things to do to it now but well on the way now
bill
There in the bin once the jobs finished but the stuff that's over the clothes I just clay we had a bit of a clay fightNice one - but.... who has got the job of 'fixing' the clothes that you're wearing?
Looks good Bill.We fixed our pizza oven well almost just got a few things to do to it now but well on the way now
bill
best to use a flat spade to lift the tiles -better than a chisel as a spade has a much wider face and surface area-also easier than bending down and easier on the knees.-Just make sure the spade is flat-when you shove it underneath
Now that I like!! Nice to learn something new. That is just perfect for feeding an inverter from batteries with double posts like mineFinally got round to fitting fuses between the leisure batteries. They are cube types fitted to a modified + battery terminal.
Link below.
http://kojaycat.co.uk/Fuse-Boxes/-Holders/Page-/-Category
Allan
Just make sure the cable is the other side of the nylon washer, not as shown in the top picture. The nylon washer has a collar that insulates the cable from the post and compresses it against the fuseNow that I like!! Nice to learn something new. That is just perfect for feeding an inverter from batteries with double posts like mine
Broken Link Removed
Broken Link Removed
