USB Plug for Nextbase Dash Cam (5 Viewers)
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
Looking to wire my nextbase dash cam in. I've installed a USB socket for the SAT nav so thought I'd plug in there rather than direct to a piggy back fuse.
Currently it has a cigarette plug on so thought I'd try just changing to a USB plug so looking for one I can wire myself.
Cal54
3,909
65,249
Southport, UK
Leisuredrive Renoir
Since 1996
I’ve just purchased a Nextbase dash cam and have also ordered the hardwire kit. I know nothing about the power gubbins so will be getting a professional to wire it in. Don’t want to use the cig socket as the sat nag uses that and I don’t want to have a bulky double adapter.
Gellyneck
10,243
21,036
More than toes wet now!
Be aware different usb output sockets can supply different amperage outputs so you'll need to take this into consideration. Does the socket provide sufficient?
Jun 26, 2018
1,109
5,883
North West
Florium Wincester
Europe & USA since April '21
I used one is these kits from evilbay. Still working fine three years later with the nextbase. The difficult bit was threading the wire through to the screen area, from the fuses under the steering wheel. But it didn't take long to fit.
MichaelT
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
It's on a 5a fuse, I looked at the hardwire kit and that had 2a I think.
CAB96
1,315
2,545
Stockport, UK
T6 Leisuredrive
Yes, but USB is 5v, not 12v, so needs higher amps for the same power.
It may be fine, have you tried it on USB?
My Garmin satnav has a dashcam built in, USB will run the sat nav but there's not enough power to run the camera.
Gellyneck
10,243
21,036
But the amperage output is determined by the USB socket with them ranging from somewhere around 1A to 3.2A. If it's one of the lower output ones it may not deliver enough to run the dashcam.
MichaelT
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
Haven't tried it as I was look8ng for suggestions of a suitable wireable USB plug.
MichaelT
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
It's 4.2a but I'm using one socket for the sat nag
Jan 31, 2016
2,095
3,819
Alness, Cromarty Firth
Hymer B534 DL (2017)
Well travelled
I used same ebay hard wire set, and yes it took longer taking the dash apart to thread the wires through to fuse box by driver. Took me a bit to find the right fuse that was ignition switched but gotthere in the end with piggyback fuse.
Cal54
3,909
65,249
Southport, UK
Leisuredrive Renoir
Since 1996
Thanks for the comments re the hard wiring kit. Has confirmed it isn’t something I could do myself!! I also got mine from FleaBay along with the reconditioned dash cam as recommended by Wombles.
Jan 2, 2024
797
1,130
Lincolnshire, UK
Peugeot boxer
I fitted a usb socket where the rear view mirror would be..powered from the interior light very easy job and if I remember correctly it's a 2.1 a twin outlet powers nextbase fine
Oct 18, 2021
2,383
7,230
Mid Devon
Adria Compact SC
Camping since 1954, MoHo 2022
My Nextbase powered base is fitted to the redundant mirror boss on the windscreen. It was a really simple job to run the wire down to the fuse box on the lower driver’s side. Pushed an electrician’s fishing rod (straightened coat hanger will do) up the inside of the A pillar cover after removing the right lower plastic cover, attached the wire, and pulled it down. The run along the top of the windscreen was eased under the lip of the top lining, so nothing is visible.
MichaelT
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
I've ordered a wireable USB plug now. Looking at the kits they are 2a so I think it will work. Watch this space.
MichaelT
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
When I had a Next base I just used a standard USB lead to 12v to USB supply mounted under the dash. Done the same with my KB camera in the new van.
How did you getbwires through, can't seem to be able to see how the dash comes off?
56,237
165,279
It was easy there is a gap along the top of the screen and down beside the back of the A pillar carefully a razor sharp aluminium down there, guess how I found out. Then along the side of the dash you can tuck it out of view. Then removed the base the monitor sits on and the speaker to get the cable through. Mounted my USB supply on the back of the panel the step switch is in.
MichaelT
MichaelT
3,988
8,393
Colchester
Carthago I 143 LE
Since 2016
Can you send a pic when you get a chance please. Was going to mount at bottom of screen but it has to go quite high due to the wipers so top would be better.
Pugsy
592
1,566
D&G
Van conversion
I changed this cigarette socket on the left to a twin usb with built in volt meter and piggy backed the the nextbase dash cam onto this underneath feeding it under the passenger glovebox.it only had to wires underneath so easy done in my Peugeot boxer.
But I pulled this one out today at the Lincoln show on the N&b arto I just got and it has 3 wires so will need to investigate and probably ask here about what wires to use😁, nothing ever simple 😅
Cheers Cris 🍻.
Jan 19, 2014
9,875
26,240
Derbyshire
Elddis Accordo 105
since 2014
Cheers Cris 🍻.
Me too. A high quality aloominum one 💫🥰
Gellyneck
10,243
21,036
Cheers Cris 🍻.
The third wire is normally for a tell tale light indicator.
