The relevant quote here is "up to 20%".... So could be, in reality, only 1%.
That probably uses more fuel than running the air conI never use Ac, windows wide open is sufficient for me![]()
The gearbox on my Honda hybrid is even simpler. Only one forward ratio and one reverse. No clutch (except for engine direct drive at motorway speeds) nor torque converter. Playing catch-up with Toyota who have been in this hybrid game for 20 + years but I think Honda might be in the lead now (just).![]()
I have seen a can of something similar to rad weld but for AC systemsMy van aircon is costing me a fortune - all because I hardly ever use it. Just forked out £60 to "fix" it but within a short time it's "broken" again. As suggested on another thread it's most likely a tiny leak that's going to be a bugger (and therefore even more expensive) to find.
It ain't cheap and sometimes you need 2 or it might not work at all. I'd definitely have a good look for the leak first, usually compressor shaft seal or condenser rotten/damaged.I have seen a can of something similar to rad weld but for AC systems
Get them to add a can when you next have it gassed
& unfortunately totally illegal.Leaving your motor running when stationary is part and parcel of using a/c it is to keep you cool.
I put this in my leaking car aircon 14 months ago and the aircon still works, before after recharge the aircon would only work for a month or so.My van aircon is costing me a fortune - all because I hardly ever use it. Just forked out £60 to "fix" it but within a short time it's "broken" again. As suggested on another thread it's most likely a tiny leak that's going to be a bugger (and therefore even more expensive) to find.
Back to where he was when first joining fun then.... Was getting the best part of 40mpg back then.![]()
Relevance to original OP please.???The new CR-V was the only thing stopping me upgrading automatically to a RAV4 when the lease on the CH-R expires next year - except that the new normal where I work means that we only need one car and the budget is now going towards a van of some sort.
What I do wonder though, is what the RAV4 (or indeed CR-V hybrid) drivetrain would be like in a van. Certainly enough power and torque and based on my experiences not significantly worse than diesel for fuel consumption. No emissions worries short term, very quiet and the big plus if thought through - you end up with a BIG leisure battery if you can tap into the lithium pack.
I can dream...
You will do if it is all low speed around town work.negligible out on mway for 500milesI notice a big difference in my car when using the air con regarding fuel.
When they were first used in the 90's you could attain 0ºc easily & at tickover. Once manufacturers started to fit it to all models it became "built down to a price" whereby the compressor hardly does anything at tickover & in most cases it cannot even keep up with an empty vehicle,doors closed with the sun shining on it.bring onto your forecourt an A/C system that can maintain a temperature of absolute zero and you will be pounds in
warm humid air contains less Oxygen therefore your car will run less efficient.
Nowt to do with A/C imo
That would be flat out here.or regulating it to maintain an appropriate comfortable temperature in the cabin.
That's good.My Fairmont station wagon only did 8mpg around town even with the air con off.Got my M5 down to 8 MPG on a autobahn last year...with A/C on
Hi.whereas at 1 or 2 in the morning you 'd still be
Yes there is nothing like them. I saw my first R730 last year up near Zaragoza.Owner driver,All black , all the add ons & trailer all coordinated . Lovely piece of kit.Hi.
Get alongside a Scania V8 going up a bank loaded.at this time of a cold morning..... Roll your window down...... Sit back and ENJOY the sound/bark/burble................. MPG ?....Whats that all about ?![]()
Tea Bag
Is that on a 5.5t extended alko tag axle??Hi.
Tea Bag
Is that on a 5.5t extended alko tag axle??![]()
Im not a complainer SD least of all about the cost of running my A/C. My post was just to highlight the fact that running A/C could cost you an extra 25% at the pumps. Followed by the Yorkshire war cry.![]()
I bet you wouldn't turn down a 3% pay rise.*if you are running massive fleet of trucks, 3% is huge. On a motorhome, negligible in my opinion.
Yes I saw that, over a certain mph it was better to have the windows closed and AC onI'm sure mythbusters covered this many years ago running a car on an oval track with air con on or windows down.....no difference in mpg
I scowl at my passengers when they don’t put windows up when I’m leaving a 40mph zone*.Yes I saw that, over a certain mph it was better to have the windows closed and AC oncan't remember how fast it was though.
