Don't notice any difference in the car or van
Another one for your book SHM bring onto your forecourt an A/C system that can maintain a temperature of absolute zero and you will be pounds in. Reading some of these posts I think some posters have reached absolute and already achieving free energy.This post is funny!
The title sounds very ominous, "The TRUE cost" of running air con. I thought there would be all sots of links for research done by Shell or BP along with some links and real world testing. Instead some bloke thinks he uses up to 25% more fuel because he made a note of it in his head. buttons I applaud you for this post.
PS I have also done some research and I have made a note that if I use a cash point, it costs me money as I have less money in there than when I started!
Couldn't agree more chaser it is a chicken and egg situation. It's Global warming that is creating these unusually high temperatures that my lovely lady can only survive in with the help of A/C. Now without GW I wouldn't need my A/C when parked. What can we do about it.?What is this about standing with the engine running just to run the AC, I thought it was a hanging offence in towns now to have your engine just running doing nothing.
Me too - mine is a 4 x 4 - wonder how much difference the type of car is makes. I consider the very few times I need it in this country to be worth it thoI notice a big difference in my car when using the air con regarding fuel.
I never use Ac, windows wide open is sufficient for meMy fueling policy in my car is to fill up then drive until the low fuel light comes on then fill up again. Now I have been doing this for some time and normally make a mental note of the trip mileage before I reset after filling. No calculations or recording just a mental note of how many miles I tend to do each week. I filled up this morning as my fuel light had just activated.
Now this week has been absolutely roasting as it is this morning with temperatures well into the 30Cs, consequently my A/C has been working full bore every day this week even when parked if needed.
This is obviously going to have an effect on my MPG so I thought I would share with you just how much it costs to use your A/C.
Nothing scientific but I had done 25% less miles this week on a tank full when my fuel light came on.
Conclusion........Using A/C could cost you 25% more on your fuel bill. View attachment 415013
HiI use the aircon a lot throughout the year and still average 32 mpg on my 120 Ducato PVC
Mine is also free. Just pedal faster.My air con is free,,,i either open the windows but mainly walk...Same on van,,i open the windows,,BUSBY![]()
This I would say so as wellMore likely to be the extra fuel used idling when stationary.
Sounds a nightmare if things go wrong,,,BUSBY![]()
As you are aware SD nothing is for nothing, we can do things more efficiently but even charging you battery on your hybrid is costing you at the pump.
Yes I have been looking at hybrids and EVs but nothing yet has attracted me enough to change over.
Cruising, as most driving is, has a very low HP requirement. Aircon use will add over 10% that requirement. And of of course I use mine.AFAIK the pump uses about 5 horsepower. At tickover that's a a large chunk out of the engine power so fuel consumption will be relatively heavy. In my car it is on by default, but it does have 258 HP available when it gets going so it's not so much of a problem.
John
Assuming we're talking Toyota hybrids here, they regularly survive >300k miles in the hands of the four door saloon men of the apocalypse (taxi drivers) with no more than routine servicing and tyre changes. No clutch or DPF to worry about and the gearbox is a simple epicyclic. They are actually less complex than a modern diesel. Everyone worries about batteries but they rarely go wrong and individual cells can be replaced quite cheaply.
I'm on my third now and they are even staring to look halfway decent, or is that Stockholm Syndrome![]()
Back to where he was when first joining fun then.... Was getting the best part of 40mpg back then.Where is the comparison of the A/C not being on. Your van may well do 38 without the a/c on![]()
Not so much these days - you're correct of course about reduced oxygen much the same as driving at high altitudes - but the ECU will reduce fuelling to match. So less power but no change in efficiency.warm humid air contains less Oxygen therefore your car will run less efficient.
Nowt to do with A/C imo
