CCC.. where did you buy the clip on trays? Only problem is if you turn the seats round???
Thanks for the info on this, I've bought one and will have a play with it when I get back off holiday (it's going to the FILs house) - I'll fit it on the roof of our PVC so won't have to worry about what direction it's facing and then decide where to run the cable but probably via the solar cable input.2G/3G/4G MIMO Multiband Waterproof Puck Antenna LTE
Seems like a bargain -- if it works
Just the little issue of finding somewhere to drill a 20mm hole in the van's steel roof without detracting from the internal aesthetics!View attachment 211541
There are loads on Ebay of various sorts and sizes, when not in use they can be removed or fold flat.CCC.. where did you buy the clip on trays? Only problem is if you turn the seats round???
........... this. Collect it on Friday next:
And feeling rather pleased .
Read the spec before chucking you lolly at it..Thanks for the info on this, I've bought one and will have a play with it when I get back off holiday (it's going to the FILs house) - I'll fit it on the roof of our PVC so won't have to worry about what direction it's facing and then decide where to run the cable but probably via the solar cable input.
@bigalw35 can you take photos or video of how you do it and the tool needed as i need to change one of mine and they will be the same, thanks RobI brought a brand new set of lock barrels for our B680, fed up walking round with a key set like a jailer, as soon as the weather becomes a little friendlier they’ll get changed
No probs XRN, an absolute doddle, I’ll take some piccies tomorrow, I got the new set (8) from Brownhills, I mentioned that I was a member of “Fun” and he Darren gave me a 10% discount, the situations are all slightly different, but basically the same, all along the barrel you have the key actuators and at the end is a similar spring loaded locking piece, this piece locks the barrel itself in, just push that in with a small screwdriver and the old barrel is out, piccies tomorrow
The only problem with that is that it would only 'receive' on that side of the camper, whereas on the roof it would be able to receive from all directions ... I'd be tempted to attach the bracket it is mounted on to the side of a solar panel frame (obviously can't do that with a semi-flex panel!) using Sikaflex or something and just run the small cables through where your solar cable goes if there's room, or alternatively attach it to something else that 'sticks up' already on the roof!
Just found a data-sheet on it:
https://www.entrix.co.uk/datasheets/CMO-SpecSheet.pdf
I've been a bit busy for the past week or so, but finally managed to install the antenna a couple of days ago on the cab roof. I haven't been able to fully test it yet, as I am currently in a part of Norfolk where it is sometimes difficult to even get 2G -- and 4G is just a pipe-dream. However, first impressions are good -- where I am now the van is parked in trees and getting a good 3G signal from Three. In this exact location I could previously only get a 3G signal by taking the mifi to the second storey of a building and hanging it out of the window!I’m interested in this,hopefully you will post how this works when you’ve got it fitted.
I had looked at it and thought I would fix it to a piece of ally box section and then stick that to the roof, so only need to drill a smaller hole (I’m thinking for the future as I haven’t got a twin antenna mifi yet)
Just made an offer too - thanks for that.
The problem is we usually leave the seats facing into the van while we are parked up, so when we go to bed there is nowhere to put the shelves .... but hey only a minor problem.....
I am hoping there's a radio engineer on here who can explain to me how gain works when it comes to a MIMO antenna -- my basic understanding is that both elements come into play when we are talking about a 4G signal, whereas a 3G signal can only use a single element. Now, as the two elements of this antenna are rated for peak gain at 3.8 and 3.7 dBi respectively in the 1710-2170 Mhz frequency range, what does that mean in practice for 4G if both elements are in play?Read the spec before chucking you lolly at it..
1dB to 3.5dB gain.... so parity ( which given cable and joint loss will become a negative figure ) to 3.5 dB ..... or in cb term, up one 'S' point.
Or ask Stanley Unwin.I am hoping there's a radio engineer on here who can explain to me how gain works when it comes to a MIMO antenna -- my basic understanding is that both elements come into play when we are talking about a 4G signal, whereas a 3G signal can only use a single element. Now, as the two elements of this antenna are rated for peak gain at 3.8 and 3.7 dBi respectively in the 1710-2170 Mhz frequency range, what does that mean in practice for 4G if both elements are in play?
@bigalw35 I have pm'd youNo probs XRN, an absolute doddle, I’ll take some piccies tomorrow, I got the new set (8) from Brownhills, I mentioned that I was a member of “Fun” and he Darren gave me a 10% discount, the situations are all slightly different, but basically the same, all along the barrel you have the key actuators and at the end is a similar spring loaded locking piece, this piece locks the barrel itself in, just push that in with a small screwdriver and the old barrel is out, piccies tomorrow
Nice bit of kit........... this. Collect it on Friday next:
Lots of bargains for the MH!Ah Boyes stores indeed. Can buy almost anything there. Scarborough family. Used to know them way back. They predate but almost invented the pound shop idea.
Not as attractive as my purple bucket Gus!!An alternator
