The valve on the heat exchanger is a Ballofix type , it is an o-ring on the shaft , it’s a common problem when used on heating / hot water systems , moving it is not advisable, it may re seat but more likely to aggravate an already perished o-ring
As a plumber I’ve seen hundreds like this
Even if re seated with movement it needs replaced as it is a leak that won’t go away
