If you put frozen stuff in then the temp should get a lot lowerFridge is now settled at 8° and freezer at -8° at setting number 3 .. Nice and cold in there now.
Thanks Ian it all seems to be up and running now anyway , I didn't doubt you I've just had rotten luck with fridges so far
No mice in there now but traces that there has been in the past..I think the buggers have been everywhere in it .Was there any mice under the dash?
We experienced the same on the way down through Spain last winter Tam. She'd be fine on the flat, but once we started climbing a gradient, she'd lose power, and the injector lamp would flash. It turned out to be a leak on the Turbo Boost hose from the intercooler, (Iveco 60C 17), so had it replaced at Iveco Blanes.The engine has the dreaded red flashing injector light when it comes to hills etc .. could be a number of different possibilities but I don't think it's anything too serious it will just be finding the sensor responsible most likely.
Yeah it might well be something simple on this , even possible it's something the garage that did the cambelt hasn't put back on properly.. finding it's the biggest problem.We experienced the same on the way down through Spain last winter Tam. She'd be fine on the flat, but once we started climbing a gradient, she'd lose power, and the injector lamp would flash. It turned out to be a leak on the Turbo Boost hose from the intercooler, (Iveco 60C 17), so had it replaced at Iveco Blanes.
HTH,
Jock.
2006 Tam. My HGV mechanic pal back in the UK guided me in the right direction as to the fault when I phoned him, but I just couldn't find it, not even with Rita on the accelerator, building up the revs to 3000rpm.What year is your van jock?
Tam - The last thing I want to do is add to your stress levels - but are you positive the cam belts have been done as claimed?? Copy invoices for records etc?Yeah it might well be something simple on this , even possible it's something the garage that did the cambelt hasn't put back on properly.. finding it's the biggest problem.
Gareth the guy I bought it from was adamant he'd never seen that light flash any time he'd driven it. Of course I don't trust him now but maybe it wasn't on .. I can't see how he could have driven it the distances he did for both mot and cambelt and it not have came on ....unless it was something that happened after the belt was done.
When I leave this thread I make a note of the page number I was up to and the post number. It's so fast moving it's the only way I can keep upAh ha. I found you and you're on to page 23 without me already.
Where are you working on it and are you living in it?
Looks good. comfortable and roomy for all of you.
Steph
Just been to lidl so I can put some bleeding food in it lol .Hope you 2 are sinking those frosty ones
I have the invoice he gave me for it . I know they never changed the auxiliary belts but the invoice has the cambelt change on it.Tam - The last thing I want to do is add to your stress levels - but are you positive the cam belts have been done as claimed?? Copy invoices for records etc?
Asking - cos your man Gareth seems to me a complete chancer. Maybe that’s harsh but it’s just the way I’m reading it at a distance.
On the positive side - superb job of van restoration you two are doing with a little help from your online friends. Full respect!!
Don't worry about food get the beers inJust been to lidl so I can put some bleeding food in it lol .
I think it's a euphemismQuestion: Why did Uncle Lenny's new van need its wheel hubs greased, was it the wheel bearings, or brake callipers?
Another quality conversionView attachment 945198
Scientific test cansSomething so wrong about that fridge.
Only 2 cans ??? Tsk tsk.
Alloy wheels notorious for sticking to the hub if you don't put a smear of grease round them.I hope Tam can get onto the oily bits soon, I hate all these warning lights that can show up and point towards a great number of things that all need checking/replacing until the actual cause is discovered, we see it happening so often thesedays. The light coming on when going uphill or when engine is needing to work harder, should be enough of a clue. but its not in so many cases.
I hope that changing all the fuel/air filters, plus checking the injector wiring loom connections will solve the problem.
Good luck, chuffed the new Fridge Freezer is working well.
You must know the way to the local tip well by now.
LES
Testers testersSomething so wrong about that fridge.
Its a Northerner taking his pigeons for a test flight weekend.Another quality conversionView attachment 945198
It’s a plan. Which lithium has Lenny HB suggested I can’t recall. Looking back memory says more. Whatever presumably yes you could add more, but how difficult I don’t know.Right then so I'm gonna be ordering my electrical bits.
Getting me victron from ebay as they're the best priced
50amp victron b2b
100/30 solar controller .
Solar panel from city plumbing
The battery is the hard part
I can get a 300ah fogstar drift from fogstar at £722
Or I can buy a 280ah eco worthy at £495
With the eco worthy I'd need to fit a shunt so I can see what the battery is doing etc.
Anyone on here fitted/used eco worthy ?
They get Good reviews online for sure.
And I guess if I needed more power later I can add a second one .
But honestly I'm not sure I'd need to .
Baring in mind I will have b2b and possibly generator as back up to solar .
Without a compressor fridge I don't see the need for more at the minute .It’s a plan. Which lithium has Lenny HB suggested I can’t recall. Looking back memory says more. Whatever presumably yes you could add more, but how difficult I don’t know.
Carol
It's possible. I did think it was a very basic invoice but I guess it depends on their relationship with the seller.The invoice for the cam belt looks iffy to me ,just looks like something to appease you , parts are usually added , then labour , then vat , same as the mot invoice ,
I would ask for a copy of their parts purchase invoice , that will tell you that they bought the parts , easy for them to email a copy to you , just say it’s for your maintenance records
