Ok I’m in on this one might get nasty, ? ? ? ?
PhoeniX put steel beams across the chassis and then build the box on top where Morelo and Concorde etc build the floor straight onto the the chassis with outriggers as shown by OurMoreloLife I don’t know why the difference unless it’s to do with PhoeniX building a lot of Alkovens and if you wear the chassis out the body can be lifted off and re chassisi’d.Got to admit he has a good point. The massive weight of all that steelwork, all the walls and fittings mounted thereon, are bending the cross beams on a straight edge. They will fail there, eventually. Will it 5 ? 10 ? 100 ? years. There will be some sag now, maybe nothing to worry about.
Hi, Looks like a big job to me! Well done for trying.
I reckon you could do with some wedge-shaped bracing arms from the chassis members out to the outer edge of the floor bars. This will assist with roll stability/ rigidity and provide a route for under-floor wiring & water/waste hoses etc.
See below for an idea of what I mean
The subframe and body are very rigid, the chassis is designed to twist. I've cobbled together a spring based mounted system for the two to move independently. If the body was bolted directly to the chassis it would definitely snap. I like what your saying, but unsure if the braces would allow the movement. I'm certainly going to look into it!!! The subframe is made out of 120mm x 60mm x 3mm and 100 x 50mm 3mm... That ain't bending. The subframe also is all going to be nut and bolted together, but that's a job for another day. I appreciate the input!!Hi, Looks like a big job to me! Well done for trying.
But I'm sure houses experience 50mph winds. There will be a foldable tailgate that covers the window during transit and when parked for security anyways ??i would think about turning the window so the opening end is the trailing edge houses dont do fifty mph and i would worry about the seals
I'm a professional fabricator/sheet metal worker for the automotive industry. This is the only part of the job I can safely say I know what I'm doing. ?. Believe me, lorry body's are made by the lowest bidder, with the cheapest materials.... This isn't.Possibly not the best phrase to use when considering 7.5 tonnes careering down the road.
Which raises interesting questions: Who says it is safe to be on the road, and how do they come to this conclusion when you won't be providing drawing with stress calculations. How do you convince someone to insure it ? I know this is very negative but does need asking right now.
Ok I’m in on this one might get nasty, ? ? ? ? Sorry meant interesting ? ? ??View attachment 323643
There have been many many self builds & conversions - so surely insurance must be available, if only through a specialist broker.No offense intended.
But the question still stands. Is what you are doing outside of regulation ? You still have to insure it and FUN shows they can be quite demanding with a "normal" MH, so it will be up to you to convince them it's sound, structurally, electrically, gas. And if you mention "full time" it all racks up a notch. I don't know if you are thinking of fulltiming but it's one hell of a build for a holiday vehicle.
Brought some metal sticks, and started glueing them together with electricity.
What do you anticipate your total investment in this project will be at completion?
Not sure of your thought processes, modern MH's including truck chassis versions like my 12 ton Morelo,
50% of the list price, maybe a tad more, the balance being dealer discount and their profit and tax however I do not understand the relevance of the question. This is a second hand chassis with a selfbuild structure, which will have comparators in the second hand market of 7.5 ton completed MH's.What do you think it costs Morelo to make your van?
Why are you comparing the build to yours then? If they are incomparable ?50% of the list price, maybe a tad more, the balance being dealer discount and their profit and tax however I do not understand the relevance of the question. This is a second hand chassis with a selfbuild structure, which will have comparators in the second hand market of 7.5 ton completed MH's.
I am not, Jim was, hence my query of the relevance of his question.Why are you comparing the build to yours then? If they are incomparable ?
Can you show more of this please.You need to make a separate subframe for the body and mount them using springs
