That looks a strange shaped seal, I initially thought it was an aftermarket DIY stick on gutter or something.
Captions ...
It's where the fibreglass cab meets the aluminium bodyThat looks a strange shaped seal, I initially thought it was an aftermarket DIY stick on gutter or something.
Possibly. I'm not sure though. Problem is the screws go rusty then they snap when removing. It seems well fixed at the minute so I might just put a 6mm Bead around it.Do you reckon that seal/cover strip will come off so u can get some real sealer in behind it?
It has that infill bead in it too which I've ordered new stuff for that. ..I'll run a thin bead of sealant over the screw heads before fitting the new infill
Our Lenny Lenny HB will tell you off for that if they go into aluminumWhy not use SS self tappers? If I can get the screws out of mine I replace them with SS
The two react with each other and the aluminium corrodesI need to ask why?
Try this one
In the same way as normal steel. But stainless much less and rarely seizes if through sealant.The two react with each other and the aluminium corrodes
He does a good job, unlike our self build neighbour last night, he has put his rooflights on back for front and 3 solar panels that I wouldn't trust over 30mph. Bob.
Oh dear they will finish up flying off without doubt,have you told the bl@@dy idiot.
I've seen a few folk doing that with skylights ...it seems deliberate but I have to ask if they realise they aren't designed for that and will likely fail over timeI would stick with Tam, if it's sealed and dry the motorhome is miles better than it was, start pulling it apart trying to make it like it came out the factory is uneconomical, it's an old motorhome and not got to be with him forever.
mmhh!!The two react with each other and the aluminium corrodes
Yep if it was easy to remove them and seal under I would, but the ones on the roof the screws were rotten. But the trim was still soundly fixed. So I opted to leave well alone for now.Speaking from experience of having to remove the whole front of a caravan years ago I would remove the strip. You can refix with new as above just drill a hole near the broken screw. U can then get the sealer in where it needs to go.
What's it screwed into? hopefully not rotten wood!
Normal steel reacts with aluminum too unfortunately there's not a lot you can do about it. Usually sealant keeps the 2 apart till that fails. Where the rotten wood has been on this van you can see where the aluminum is starting to corrode. I have a series of little pin holes along one section which I can do nothing about other than a smear of sealer along inside before I bond the new wood too it.mmhh!!
in 1991/3 I built a show winning car, it was fibreglass and aluminium construction and every nut bolt and washer were stainless steel on the bodywork attaching the aluminium panels to their appropriate fixings.
30 years later the car is still as it was the day I finished it and looks brand new with no signs of any corrosion anywhere.
Sorry Tam for any thread derailment
Yes an excellant way of starting corrosion.Our Lenny Lenny HB will tell you off for that if they go into aluminum
So what type of screws are best then through aluminium?Yes an excellant way of starting corrosion.
Yeah I know ..but that said I'll be checking the seals I put round stuff every so often and redoing as and when necessary all these sealants are only ever meant to last 5 to 10 years before they start to crack or shrink etc so really everyone with a van over that age should be checking or resealing windows and skylights anyway.Tam I know u are doing your best - not suggesting otherwise for 1 minute.
Modern sealers/mastic etc you get nowadays are so much better than they used to be.
Just seems a pity that all the hard work your putting in and replacing the interior paneling around that area which my leak again if you are unlucky.
and a less excellent way of starting corrosion is………… ?Yes an excellant way of starting corrosion.
Plated steel will rust but won't set off corrosion as much with the aluminium.So what type of screws are best then through aluminium?
it hasn’t happened to mine in 30 yearsPlated steel will rust but won't set off corrosion as much with the aluminium.
Stainless steel self tappers with set off galvalitic corrosion and the aluminium just gets eaten away around the screw.
You can reduce the effict buy using a sealant on the screw but with a self tapper there will always be a point off contact.
Much less of a problem when using nuts and bolts as you can put a barrier on the mating surfaces.
If the aluminium is anodised which most is on motorhomes etc you will be okay using stainless steel fittings.it hasn’t happened to mine in 30 years
Have you taken the screws out to see?it hasn’t happened to mine in 30 years
Only on surface contact like head to panel. A self strapper will be biting into raw aluminium & the hole will just corrode away.If the aluminium is anodised which most is on motorhomes etc you will be okay using stainless steel fittings.
