Aye. C’mon Tam - you big tease ???!!!I've missed something here what have you bought
What have you got?
It was in Gainsborough I went there yesterday . It goes OK, gears take some getting used to as back to front and on the wrong side lol . But it has plenty oomph for an old bus . Finding it had cruise control was a bonus.What does it go like ,I thought that one was in Gainsborough
Is there a psyco vibe hereI like it too. You are going to have some fun with that shower curtain. It reminds me of my first flat when I used to battle with the shower curtain clinging to me![]()
I plan to remove all the habitation windows clean them all up and reseal them properly. The windscreen I can't tackle myself as its a bonded screen but I'll clean off all the silicone etc and see if I can just seal it outside . If not then I'll see if I can get a windscreen fitter to remove it and reseal for me. Fortunately there's no damage been done on the side windows from the leaks other than a few water marks . But the rear window in bathroom has caused a bit of soft wall behind the panel . So I'll probably have to remove the panel and see what can be done to sort that.Can the windscreen and windows be removed and resealed ?
Sounds like a big job and hopefully no water damage inside.
Use mirror film so you can see out. Don't shower when it's dark outsideI plan to remove all the habitation windows clean them all up and reseal them properly. The windscreen I can't tackle myself as its a bonded screen but I'll clean off all the silicone etc and see if I can just seal it outside . If not then I'll see if I can get a windscreen fitter to remove it and reseal for me. Fortunately there's no damage been done on the side windows from the leaks other than a few water marks . But the rear window in bathroom has caused a bit of soft wall behind the panel . So I'll probably have to remove the panel and see what can be done to sort that.
I took all the windows out my last mobilvetta and did the same. I tinted them all too but not doing that again. I will however put some opaque film on the bathroom window as I often think a window in the bathroom is pointless , can't use the facilities with the blind open and when you close the blind it's pitch dark in there.
You said it had been downplated. What weight is it/was it?I plan to remove all the habitation windows clean them all up and reseal them properly. The windscreen I can't tackle myself as its a bonded screen but I'll clean off all the silicone etc and see if I can just seal it outside . If not then I'll see if I can get a windscreen fitter to remove it and reseal for me. Fortunately there's no damage been done on the side windows from the leaks other than a few water marks . But the rear window in bathroom has caused a bit of soft wall behind the panel . So I'll probably have to remove the panel and see what can be done to sort that.
It hasn't... just another owner who knew nothing about his van.You said it had been downplated. What weight is it/was it?
Probably not .If you're tearing the shower room apart - can you not make it waterproof so you don't need the clingy shower curtain?
battery powered LED will be safe in shower....Duracell etc.Probably not .
It's still 4200kg on v5
I would go to great lengths to get rid of the shower curtain
I hate them they cling to me and always seem cold however hot the water.
I must point out I do not have a shower curtain either in the motorhome or house, but have experienced them in several hotels.Try using the shower without the curtain - I've a wetroom at home, no screen, van leave the curtain, just an old towel on the floor outside the tray - hardly any water outside![]()
Thats the worst as you know they’ve cling to a myriad of other nether regions ….I must point out I do not have a shower curtain either in the motorhome or house, but have experienced them in several hotels.
Tam showering outside, not a pretty sight.It apparently has an outside shower too but not seen that yet.
