If the fitter has fitted that heavy box back on his own he my well have bent the fingers on the pressure plate with the first motion shaft of the gearbox .... is the bearing still in the end of the crank I wonder
That won't wash . Ill be phoning them on monday morning first thing to tell them how it was on the drive home.I hope the garage don't say it was alright when it left here after we tested it.
It is a bit more complcated to fit & if doing it on the floor , as we did, having 2 people to align it makes a difference.I can't remember on the alfa pull clutch but on my 2007 transit the fisrt motion shaft does not sit in the end of the crankshaft anymore. I checked when it was out the other week & I'm sure it doesn't but when it comes out again tuesday I will check again.If the fitter has fitted that heavy box back on his own he my well have bent the fingers on the pressure plate with the first motion shaft of the gearbox .... is the bearing still in the end of the crank I wonder
With these once the release bearing is attached to the pressure plate it can't be removed. The gearbox can't be removed without either popping the pin out of the fork or by removing the bolts for the pressure plate through the inspection hatch and taking the box, pressure plate and clutch plate off in one.It is a bit more complcated to fit & if doing it on the floor , as we did, having 2 people to align it makes a difference.I can't remember on the alfa pull clutch but on my 2007 transit the fisrt motion shaft does not sit in the end of the crankshaft anymore. I checked when it was out the other week & I'm sure it doesn't but when it comes out again tuesday I will check again.
With the alfa pull clutch, & having never seen/done one before, we actually attached the release mechanism to the pressure plate to see how it worked before attaching it to the release arm. It certainly grips the fingers of the plate & was difficult to remove again. Once attached to the gearbox release arm it attached quite easily & with a pronounced clunk as the release bearing clipped on the fingers. 2 people make the difference.
Can that upright bolt to the outside where you can see the bolt heads.Got the scooter rack fitted on but had to do a bit of fettling to get the upright bar on that holds the seat brace. My bumper fouls it if trying to put it on the right way so im hoping this way works.
Might be easier if yours is north to southWow I hope our Iveco 3 litre 2005 isn’t as complicated as it’s on the original clutch although no problems with it whatsoever.
Yours is rear wheel drive so its a different box and a lot easier .Wow I hope our Iveco 3 litre 2005 isn’t as complicated as it’s on the original clutch although no problems with it whatsoever.
Proper vehicles have a longitudinal engine!Yours is rear wheel drive so its a different box and a lot easier .
you beat me to that answerI think what you need is a old Merc to do up.
I hate seeing you so pissed off . It’s a good van and a solid engine. You will get this resolved soonWell ive brought the van home but its not right. It wont go over 40 in 4th gear and struggle to get 60mph in 5th . And reverse is unbearable it just judders like hell. Not to mention it still bites near the top and there is still a rattle.
Basically its worse than it was when it went in .
And im just really pissed off.
I will have to phone them on monday and see what they want to do. Ive lost the will to live.
I picked it up yeah.Did you get the scooter,was the trip ok?
Yeah but it went over 40 the other day too , it won't win any performance trophies though thats for sure.Could you get it over 40 mph ?
Aye but the upright bar wasn't right. Im gonna make my own one tomorrow as the scooter was leaning too far off the back. I have a length of 40x40 box section here anywayDid the scooter rack work out ok
He is anything but…..Van Tam, isn't he one of Boris's cronies?
Good guy by all accounts!He is anything but…..
Shows how much notice I take of politicsHe is anything but…..
