whats wrong with Alphabet spaghetti's!!
Have you tested glow plugs ? You might only have 1 or 2 working ones left? That makes for a bad starting engineNot really mornings are a nightmare , its definitely worse when cold and been sitting ...better when its warmed up. I will have to get it looked at somepoint but i think greece or bulgaria etc might be cheaper![]()
Crikey! That was quick!think he,s in Italy,?
The only thing ive done under this bonnet is check the oilHave you tested glow plugs ? You might only have 1 or 2 working ones left? That makes for a bad starting engine
Always a good start lolThe only thing ive done under this bonnet is check the oil![]()
Aye i think ill be looking in to getting a timer controller for this eberspacher . I plan to pinch it for the vario build .or at least put the controller where i can access it in bed .Thought you were up early, our came on on the timer at 6:50.![]()
Could it be lack of fuel for starting, ie a 'choke' type issue? Another thing could be a clogged up carb or it needing a new air filter (can't remember if you did this or not).
I didn't know.Errm, it’s a diesel.
Ian
That explains a lot … I couldn’t work out why this didn’t look like a bus and why you’d built something you didn’t really likeHymer is sold , vario is mid build ...so i bought this heap to do till its finished![]()
Which one was that ?not passed that lovely big lake![]()
Cant remember the name but i discovered i took a different road last yearWhich one was that ?
Nope the heater light goes out almost instantly every time....but when cranking it the red injector light flashes when its trying to start. ...it does always start it just takes a few cranks first thing in the morning and occasionally when its warm but mostly when not been running for a while. ..Tam
As I said in PM to you I am trying to catch up, having travelled in the opposite direction fro Greece only a few weeks a couple of weeks ago.
You seem to be moving quite fast but so did we but using the Go Box. That was because of need to get back to Basia's Mother - plus another reason - more news on that tomorrow.- no, Basia is not having a baby!
Re starting problems, does the pre-heat light stay flashing after starting for about 30 secs? It does on my Fiat, which means one or more heaters are not working.
Hope you get it sorted.
Good travels laddie.
Geoff
Don't tell me she's made an honest man of you!plus another reason
