zac
The K1 Max is a nice machine that's for sure.I have the swish end on my K1 Max.
That is concerning as just having 2 wires run today directly from the leisure battery to power my dishy dualie that i received just before xmas, good to see they are sending out replacements but not good that they are failing already. Debating now whether to leave it on 230v to avoid the hassle as had zero issues whilst away in Spain over xmas for the 20+ days.Not my best weekend on the technology front.
Starlink was working well until mid tv program it disconnected never to be seen again.
Back home and testing found that the dc-dc convertor providing a stable 12v to the dishy dualie pcb had failed.
Bypassed the faulty unit and fed 12v from EBL directly to the dishy dualie without any improvement.
Measured incoming 12v @ 13.1 with no load, connect to the dualie and it drops to 2-3v irrespective of any load on the board I.e. Starlink and router connected or not.
Tested the dc-dc unit again and this now outputs a few mv.
Not sure what caused the issue or which unit failed or if one failed and took the other with it?
Emailed boondocker in Canada and they immediately shipped a replacement pcb without question - my suspicious mind thinks they may have seen this issue already - or is it just good customer service? Tracking says delivery due by 22nd.
New convertor ordered today.
In the meantime I'm going to fit an RJ45 onto the original Starlink router and try that, if I can get my reversed cable connections the right way around, although my Starlink subscription has now expired for this month so will be another £85 to test it, that may have to wait until shortly before next trip away I think.
Not to worry I thought, just revert to normal Teleco satellite in the meantime. Last used in France in September. Found that the dish is constantly rotating, looking and failing to lock onto a satellite.
Spoke to a few companies without any success until Anthony @Oystertech directed me to one of his dealers. No updates outstanding so its a suspected faulty LNB - new one ordered and arriving today. Hopefully that will fix that issue.
Don't you love technology!
Interesting that they are sending out spares but not the actual ordersI love that Boondocker can send you a replacement dualie when I'm still waiting for the first one I ordered in September!
Are you wiring in a switch just out of interest to control the power?Yep, just finishing wiring mine up too!!!
I did on mine as the starlink is relatively power hungry so no point in running it 24/7 if not in useAre you wiring in a switch just out of interest to control the power?
got any pics? will help me when i do mineI did on mine as the starlink is relatively power hungry so no point in running it 24/7 if not in use
I ordered mine 14 July it arrived in December, as by then I had it all wired and fitted using the starlink router, l can't muster the enthusiasm to fit it.I love that Boondocker can send you a replacement dualie when I'm still waiting for the first one I ordered in September!
I will when I put it back togethergot any pics? will help me when i do mine
excellent thanks, very neat setup.Just found this from previous post before it was tidied off if it helps. The pcb is in the box with the 3 way switch. 12v psu is the silver fins above and the blank plate has the incoming 12v from ebl to psu
Hi, have finally bit the bullet and spliced my starlink cable so I now have 2 manageable lengths that can be re attached should I require a longer lengths due to obstructions.
Steve
it's the easiest part it really is, cutting the motor off the back was a lot more scarierStill not brave enough myself!![]()
I have the same problem, sharing the signal from my static caravan to my sons 4 meters away next door, drops to around 20mb. tried the starlink mesh...same !I had to mount the starlink router ‘on show’ and it was crap speed compared to the TP.
If you are using the starlink router. Then get the Ethernet adapter and run a cat 5 cable to his static. Then in his static have a wifi router if he needs it.I have the same problem, sharing the signal from my static caravan to my sons 4 meters away next door, drops to around 20mb. tried the starlink mesh...same !
good newsFinally got a text from Royal Mail yesterday saying a delivery from Boondocker was on it's way, glad I wasn't in a hurry!
I blew the same router up using a buck x to x convertor as some how the buck after i set the voltage to 12v changed which i have no idea how as the dial is so tiny and it was in a printed case but result was router would not boot anymore.Router link if anyone is interested. TP-Link Next-Gen Wi-Fi 6 AX3000 Mbps Gigabit Dual Band Wireless Router, OneMesh™ Supported, Dual-Core CPU, HomeShield, Ideal for Gaming Xbox/PS4/Steam, Compatible with Alexa (Archer AX53) https://www.amazon.co.uk/dp/B09TPKT929/?tag=mhf04-21
It's odd that the expected delivery is 22nd. Left BC on the 9th and it was Heathrow clearing centre on the 11th - what takes so long to get it from Heathrow to Newcastle?Not my best weekend on the technology front.
Been posted already, they started offering refurbs just before xmas, its a pretty good price considering there is not much that they can do to refurb one so most are going to look like new.Great new deal out I saw on BookFace.
