Tombola
And not only them. Others are launching thousands tooMust be getting very busy up there.![]()
Folks, anyone got a tidy grommet/passthrough solution for getting the cable into the hab area? I’ve been coming through a cracked open window but that won’t do in the winter.
I use the Starkink in the van and also in a holiday home so need something that comes apart and goes back together again easily.
Thanks. Maybe I’m missing the obvious, but how does the cable get inside?Have a look at post #592 for the solution I’ve used.![]()
Pretty much the same as myself as i just took out the TV Antenna and made up a box to fit inside this hole and fed the cable through which leads straight into my back cupboard where the Router is.Through the roof with a cable junction box. I removed the sat dish, so used existing entry point…
No it still requires the 12v hardware like a transformer or the dishy dualie, its sole purpose is to to prevent you cutting the cable coming from the dishy which makes it easier to convert to 12v.Is the above something you can just plug in to a 12v socket and go, per the diagrams? Does it still use the original Starlink router?
it needs to be in a static location which is the same location you put in your account, you could just keep changing this when you move around but thats a lot of hassleJust as a sanity check remind me why the home/residential version can’t be used for us MoHo people ? As i assume we need the “Roam” version, correct ?
I know it’s probably written here is this thread but wondered if anything has changed or indeed if anyone is now using a home version on the road ?
If anyone is interested i have a spare one of these coming (see link / pic below), i ordered 2 as was cheaper but it allows you to convert to 12v (with additional hardware) without cutting the main cable. Might be useful for some people, will be sold to cover what I paid plus postage, these are very hard to get hold of and there are loads of videos on youtube showing how they are used with the starlink
Here
Yaosheng v2 dishy for info
I should have a direct line to you lol for selling all my thingsI will have it! Ta!
no its only 1 as the first one he purchased was the boondocker dishy duolie which this can be used with, from what I can see the sole purpose of this device is so you can use the original lead without cutting it and then connect a standard RJ45 lead to the device used to convert to 12v (in simple terms). there is obviously more to it that this but thats the basics.Carpmart
I think that’s two of those you’ve bought!
I was hoping to get the second one Zac is selling![]()
The best solution is from what i can see is the dishy dualie (boondocker) along with the Yaosheng v2 adapter (saves cutting cable), that way you wont invalidate any warranty by cutting anything when using it on 12v.
I watched a few youtube video's on this a while ago and the difference was not enough for me to worry about but there are loads out there. The most recent one i watched was this one Here the power tests are at the end of that one but there are loads on youtube. Incidentally it has info on how the Yaosheng v2 fits into the mix with 12vzac
Zac, I think I saw in one of your posts that you thought the power savings on 12v were not that worthwhile compared to 240v through an inverter,
I'm not questioning your point of view but wondering what power the router and dish use on 12v compared to 240v via the inverter.
Any comparative information would be appreciated.
Thanks Martin
In my opinion there is No point buying the yaosheng poe injector as it costs more than duolie dishy and then you still need a 12v to 48v convertor. Just as well buy the duolie dishy which has the converter built in.AFAIK the main reason for using the above along with the PoE injector is using 12v to power the dish and to ditch the StarLink router in favour of your own router. The StarLink router has very poor range and is IMO quite basic on what it offers
Still 100 on the roam plan. I'll check for home plan now.Just as an aside my wife was looking this morning & said that the monthly cost in France was only40€? Anyone in France using it know if that is correct?
We are definitely considering it here at home now as the signal & mobile signal is never going to get any better. Just need them to do an offer like they did earlier in the summer.
