Order a starlink one and then say it’s not suitable and ask for refundAnyone got a pole mount they don’t need then?![]()
Oye that’s my trick.Order a starlink one and then say it’s not suitable and ask for refund![]()
Yes it does cos I got another £52 in the bank so I’m using that to offset what I paid for my cheap Starlink kit.No, you’re an optimist, getting a free pole mount doesn’t reduce what you paid for the rest of it.
Ian
Connecting on 2.4ghz or 5ghz has nothing to do with the Internet speeds. That's the speed from your device to the router. Sounds to me as maybe they have not got enough satellites yet to secure consistent high speeds. Can't say for sure as not had chance to test mine on the road yet.I did get in touch with customer support as speeds got slower. I have received the following reply (app won’t let me copy to paste, so have attached as two images
View attachment 770456 View attachment 770458
I knowOye that’s my trick.
Duh! You stupid or what blah blah blah.
Lol![]()
ok. I am confused? Why are you stripping down the router? I thought overlanders cut the back off his dish?First stage of making the router work on 12v as per The Overlanders mod...
Almost there
And done !!
Next stage is to solder wires onto this part
That's to flat mount the dishy only, nothing to do with the router and 12v.ok. I am confused? Why are you stripping down the router? I thought overlanders cut the back off his dish?
You're right, that's one way if doing it. The way I am doing it as per the overlanders is not to cut the cable but to mod the router. I'm not suggesting it's the best way, or even the easiest way but its a simple modIf you want to do 48v without the router then I thought you bought the ethernet adapater and cut the cable on that to inject the voltage. No need to take the front off the existing router?
Starlink Shop
shop.starlink.com
I wasn't criticising you. I was just confused as to why you would choose the hard way? Cutting a replaceable cable has got to be easier than potentially knackering a major component you cannot step back to?You're right, that's one way if doing it. The way I am doing it as per the overlanders is not to cut the cable but to mod the router. I'm not suggesting it's the best way, cheapest way or even the easiest way.
I didn't think you were being critical!! I just fancied doing it that way, as I said it might not be the best or easiest. I even bought a new RJ45 crimper to cut the cable but decided to go down a different path.I wasn't criticising you. I was just confused as to why you would choose the hard way? Cutting a replaceable cable has got to be easier than potentially knackering a major component you cannot step back to?
I will be ordering a spare cable and butchering that to do the PoE injection![]()
Yes exactly as that's what I am going to doJust remembered the cable it completely removable from dishy so you can forgo the ethernet adapter and just cut the main cable for injection.
No I don’t have any fantasies but please stop sending me messages with photos of you in leather gear, it’s put me off my tea.I might be stupidbut I’m a realist!
Whereas you’re a fantasist!
Ian![]()
Dave, I'm sure you've really thought it through. My concern would be if someone (not necessarily you), operated the inverter for another appliance with the Starlink lead already plugged in, before the male end was plugged in to the satellite socket, thereby exposing live 240v pins to the unwary operator, ie, you.I would then make up a male to male lead to link the two together.
I don't really understand what you are doing sorry. But I would not use those connectors for anything other than feeding in 240V. Sorry If I am misunderstanding you.Which blue euro plugs ?? Happy to consider anything that is small and achieves the same thing
These are what I'm thinking about but if I could get something smaller. I am looking to see if I can find the cloverleaf laptop style as I think they would be smaller
