The Coops
I am not advocating that we should break the law but given the fact that there are 20,000 police officers less than 2015 and that on average each Police force has between 8 and 15 officers qualified to weigh vehicles and that given natural wastage it would seem that there exist about 30 police officers for the whole of Britain and Wales ( Scotland is another matter) who are qualified to pull you over and direct you to a weighbridge within 10 miles of where they are operating from unless they have a mobile dynamic weighbridge in which case it narrows it down even further............The basic rule is be sensible and make sure that if you are ever pulled you can reduce your weight dramatically 1kg for each litre of water or fuel ..........boot out the Mrs and the dog and all the accessories that you must take on trips............fill in the gaps at your own peril!!! most vans will be well under MPW ( Max permissible weight) Those who are caught are probably the ones whose rear axle is dragging on the road..........Balance the load and look at the level of the van........from the horse's mouth so so speak that is what gets you pulled over, if your van looks unbalanced because its either front or rear end heavy then a *tug* is inevitable as its an easy *process* (prosecution) with a guilty plea. If you are pulled over dump the water and waste asap on the grounds that you were looking for somewhere environmentally friendly to dispose of it, a legitimate excuse, get the pushbike etc out of the boot on the grounds that there are only used on your destination, dump the passengers on the grounds that the trains were on strike and voila under weight.............on a serious note it is your insurance company that would be looking at every way out of paying up if you were involved in an accident and you were found to be overweight it is the perfect get out for them, your chances of being pulled by the old bill are less than winning the lottery!
1, Find out the max load for your van, its on your plating certificate usually under the bonnet
2. Find and go to a weighbridge most Local authorities have them usually near the tips Get van weighed on each axle and overall its around £10 and keep the certificate
3. Investigate the cost/feasibility of up-plating the van from 3500kgs if you are under 70 its a no brainier as the road tax is only £165 a year, less than the cost of a medical or driving test to upgrade!
4. Your van or base vehicle would have originally have been designed in the first instance for loads up to between 3500 kgs and 7500 kgs it is your licence entitlement that restricts you.
5. Be sensible and spread the load don't pile everything on the rear axle.
6 Wait for it..........fit commercial van tyres.............just check on the load rating before you do....Motorhome tyres are usually rated for higher speeds, commercial tyres for loading. If pulled show the officer your weight certificate ............something must be wrong with the weighbridge as you are responsible enough to ensure that you are within the limits
Last but not least if pulled eat humble pie and 9 times out of 10 no action if perceived as a genuine mistake, advice given remedy on the spot (see fuel water and wife!) And if prosecuted bad luck as must be down on targets for day , which they NEVER have!
And wait for * I knew someone who or my mate was, or I was only going to* ...............the odds on being done in a motorhome for being overweight are less than winning on the National Lottery you are not a priority for VOSA or the Police it is overweight LGVs that they are after for the damage they cause to the roads not Mr and Mrs Joe Public on their holidays
I refer to my opening statement I am not advocating that we break the law but there you have it!
